Top Noise
Gigmeister
Posted 2005-04-01 8:21 AM (#156941)
Subject: Top Noise
April 2005
I am recording tracks for a new method book to be released later this year with my Ovation Custom Balladeer 8162 with FET 3 preamp. I did about 15 tracks before I noticed the bridge has become microphonic. I'm getting a low frequency "bump" each time my hand touches the bridge and it goes on hard disc with an unpleasant sound. The only way around it to not touch the top. I've played Ovations for years and never had a problem with this until now. Any ideas? Can the Ovation bridge pickup actually go bad the way a traditional pickup can? Thanks in advance.
Posted 2005-04-01 8:28 AM (#156942 - in reply to #156941)
Subject: Re: Top Noise
good question
Posted 2005-04-01 8:37 AM (#156943 - in reply to #156941)
Perhaps related...I found that if my fingers brush the textured top of the EliteT, the vibration is transferred to the pick-up.
Bluebird
Posted 2005-04-01 4:56 PM (#156944 - in reply to #156941)
My brother had that perticular problem with his Ovation Anniversary (1978?). I'll ask him what he did to cure it.
Wayne
luthier444
Posted 2005-04-02 8:57 PM (#156945 - in reply to #156941)
Check the ground wire under the saddle... The old pin piezo pickups check the post that the wires attach to.. It may be loose??? May cause wierd feedback or hummmmmmssssss.. If loose or broken you may solder it yourself... Rick weldon had this problem and that was it.. It can turn the pickup into a microphone sometimes. If it is not the pickup it may be over hot electronics. It happens changing shims a lot
Gigmeister
Posted 2005-04-05 6:44 PM (#156946 - in reply to #156941)
April 2005
Thanks- I've never had this problem before.
Gigmeister
Posted 2005-04-05 6:45 PM (#156947 - in reply to #156941)
April 2005
BTW, I wrote the numbers wrong- it's a model 1862 with the FET 3 preamp.
