LX NECK QUESTION ???
Abendicum
Posted 2005-07-31 11:49 AM (#142270)
Subject: LX NECK QUESTION ???
June 2004
On the LX guitars, I understand the necks can be removed by unbolting 2 bolts... Are there any glue joints, (under the fretboards) that would prevent removal by an owner, for either 12 String Guitar:
On a 1656LX, the fretboard extension over the spruce top... is it glued to the sound board on a Legend LX, or will the neck and fretboard come off w/o a hassle ???
It appears on the Elite LX with, the tapered fretboard in the LX brochure, that there is very little area unsupported over the sound board and would seem to lift off... Is the fretboard neck joint glued onto the body in anyway ???
Ab
Posted 2005-07-31 1:45 PM (#142271 - in reply to #142270)
Subject: Re: LX NECK QUESTION ???
My impression is that it's the two bolts and nothing else. Why would you want to remove the neck?
Posted 2005-07-31 3:31 PM (#142272 - in reply to #142270)
See, this is why it would be good to have an "Official" response person.
The bolts hold it on but the fingerboards used to be bonded to the top as well. Don't know if they still do that.
Posted 2005-07-31 3:34 PM (#142273 - in reply to #142270)
The top is routed to accomodate the fretboard, so I would presume that it is glued in place. Just a guess. Dave
Abendicum
Posted 2005-07-31 4:46 PM (#142274 - in reply to #142270)
June 2004
Moody, I am trying to buy a new 12 string from AL, but I want to put a shorter scale on it. I will probably make my own neck. Trying to see how much of a hassle it is to get the old one off...
Ab
TexasDoc
Posted 2005-07-31 9:05 PM (#142275 - in reply to #142270)
Let's try it so we can let everyone know how easy it is.... you first!
Posted 2005-08-01 12:49 AM (#142276 - in reply to #142270)
A shorter SCALE neck? Man, just calculating the fret spacing and grooving it correctly would baffle the heck out of me. Good luck brother. Dave
Abendicum
Posted 2005-08-02 4:35 PM (#142277 - in reply to #142270)
June 2004
I spoke to K.K. at the mothership... There is no glue holding the neck/fretboard onto the the guitar on LX's...
The Fretboard is of course glued to the neck...
But loosen 2 screws and the neck is off...
Ab
jyam4
Posted 2005-08-02 5:08 PM (#142278 - in reply to #142270)
April 2002
Ab...
As interesting as that sounds (I like to experiment, as well), I would proceed with EXTREME CAUTION.
Joe
bauerhillboy
Posted 2005-08-02 10:02 PM (#142279 - in reply to #142270)
What caution???? I say have at it! tear it apart! What's the worst that could happen?
jyam4
Posted 2005-08-02 10:52 PM (#142280 - in reply to #142270)
April 2002
...wood, strings, and lots of tears.
Joe
Posted 2005-08-03 7:55 AM (#142281 - in reply to #142270)
"A shorter SCALE neck? Man, just calculating the fret spacing and grooving it correctly would baffle the heck out of me. Good luck brother. Dave"
Let someone else do the hard work at StewMac
Why worry? Plagarise!
Posted 2005-08-03 8:24 AM (#142282 - in reply to #142270)
. . . it'd probably be less of a hassle to just have a longer left arm grafted onto your torso . . .
luthier444
Posted 2005-08-05 8:54 PM (#142283 - in reply to #142270)
Lx guitars are bolted on completely.. The mid and deep bowls have 3 bolts, 2 in the heel and one in the FB block. Super shallows have 2 bolts, one in the heel and one in the FB block. Remove the FB bolt first because you cant remove the top heel bolt cause the FB bolt is in the way... Reattaching the neck do the opposite.
Posted 2005-08-06 2:41 AM (#142284 - in reply to #142270)
And we all made fun of Taylor for bolt on necks ...
leftovertion
Posted 2005-08-06 4:04 PM (#142285 - in reply to #142270)
July 2004
Not me ... I made fun of Taylor for lots of other reasons!
tpa
Posted 2005-08-07 8:31 AM (#142286 - in reply to #142270)
http://www.ovationguitars.com/?fa=lx
Posted 2005-08-07 8:38 AM (#142287 - in reply to #142270)
Taylor is easy to make fun of but not for the necks. If you want a shorter scale why not just permanently glue a capo to the 2nd fret? Then take a black marker and black out all the fret and side markers and with white out put them back in the right spots.
What's so hard about that?
Abendicum
Posted 2005-08-07 9:26 AM (#142288 - in reply to #142270)
June 2004
I have done as you say... (w/o glue, blk markers & wht out)
It's a bitch to tune though...,
Ab
Posted 2005-08-07 9:33 AM (#142289 - in reply to #142270)
Modify a nut to fit over the second fret.
