I don't belive it. was 1777LX action adj.
| williamfriggle |
Joined: April 2003 Posts: 183 Location: Denver, PA USA | Well the question of to remove shims or not has been answered for me. I removed my strings to remove a shim or two and found that there is not a single shim in my 1777LX. So I guess I am stuck with the action I have. I was so hoping to get a bteer action. My Ultra cheapy from the 80's has better action than my Legend. That just doesn't seem right. Bill | ||
| moody, p.i. |
Joined: March 2002 Posts: 15686 Location: SoCal | Did you buy the 1777LX new? | ||
| MWoody |
Joined: December 2003 Posts: 13997 Location: Upper Left USA | Bill, I can see your frustration and I don't want to sound condescending but it may be time to take it to a Pro to assess the tension and action. That just doesn't seem right. A return to CT might be required. When measuring from the 12th fret to the base of either E string what does it measure? Next assess the "bow" using the steps in the manual. | ||
| williamfriggle |
Joined: April 2003 Posts: 183 Location: Denver, PA USA | Originally posted by moody, p.i.: Yup. Bran spankin new. Go figure.Did you buy the 1777LX new? | ||
| williamfriggle |
Joined: April 2003 Posts: 183 Location: Denver, PA USA | Originally posted by MWoody: I checked the bow and it is right on. I considered paying for a pro set up, but money is a major issue right now. Believe me it isn't horrable at all. But I know it can be better. I can play it fine the way it is. But would like it just a little lower. Bill, I can see your frustration and I don't want to sound condescending but it may be time to take it to a Pro to assess the tension and action. That just doesn't seem right. A return to CT might be required. When measuring from the 12th fret to the base of either E string what does it measure? Next assess the "bow" using the steps in the manual. Oh well. Bill | ||
| MWoody |
Joined: December 2003 Posts: 13997 Location: Upper Left USA | Call Customer Service. They will right any wrongs and such. 800-552-4681 | ||
| moody, p.i. |
Joined: March 2002 Posts: 15686 Location: SoCal | If you bought it new, it's under warranty. Also, new LX's, from what I've learned on the board, usually come with the factory setup, which means there are 2 shims under the saddle, one thin and one thick. If they aren't there, then I wonder if somebody at the store, where you bougtht it, messed with it. | ||
| cliff |
Joined: March 2002 Posts: 14842 Location: NJ | Another "solution" would be to have the saddle-slot routed a BIT deeper . . . BUT . . . you'd REALLY have t'do your research, and find an extremely competent luthier to do this for you (as opposed to "Danny Dremel") . . . | ||
| williamfriggle |
Joined: April 2003 Posts: 183 Location: Denver, PA USA | I emailed Kaman and told them of the situation and asked what can be done. We will see if they respond and what they have to say. Bill | ||
| leftovertion |
Joined: July 2004 Posts: 338 Location: Omaha | Have you adjusted the truss rod (and are you comfortable doing so)? Even if it looks straight, you might have some room to tighten the rod a little more - a slight adjustment can make a huge improvement in playability...especially if, as you say, it's not THAT bad right now. It's worth a try...and if you're not comfortable doing it yourself, follow the above advice; take it back to the dealer and have them do a set up. | ||
| Standingovation |
Joined: June 2002 Posts: 6202 Location: Phoenix AZ | Routing the pickup slot is standard work for any good shop. That's how all Fishman type pickups are installed. You could also sand down the back side of the pickup (slightly). Dave | ||
| williamfriggle |
Joined: April 2003 Posts: 183 Location: Denver, PA USA | Originally posted by leftovertion: I have done this on other guitars I have owned but to me I checked as per the owners manual and it is right in line with what they say. Maybe I will give it a tweak and see what happens. Can always go back the other way. Have you adjusted the truss rod (and are you comfortable doing so)? Even if it looks straight, you might have some room to tighten the rod a little more - a slight adjustment can make a huge improvement in playability...especially if, as you say, it's not THAT bad right now. It's worth a try...and if you're not comfortable doing it yourself, follow the above advice; take it back to the dealer and have them do a set up. Bill | ||
| williamfriggle |
Joined: April 2003 Posts: 183 Location: Denver, PA USA | I just gave the truss rod a little tweak. I will try it tomorrow. I have to go to work now. :mad: Maybe I will take her with me tonight. Bill | ||
| bauerhillboy |
Joined: February 2004 Posts: 1634 Location: Warren,Pa. | WORK???DID HE SAY WORK??? How can he go to work at a time like this??? Bill needs to reassess his priorities. | ||
| Old Applause Owner |
Joined: July 2003 Posts: 1922 Location: Canton (Detroit), MI | Well, he DID say he might take the guitar to work with him.....sounds like a good idea to ME. Roger | ||
| williamfriggle |
Joined: April 2003 Posts: 183 Location: Denver, PA USA | Yeah but I didn't. Wish I had. It would have helped me stay awake. I was thinking about her the whole time. I am going to take her to church today and plug her into the system and jam with her and the drum machine. | ||
| richardd |
Joined: May 2002 Posts: 651 Location: Australia | Bill, I wouldn't touch it. It's a new guitar ! Let the dealer/factory put it right or replace it. It's a new guitar,you've just shelled out the cash, you shouldn't have to put your hand in your pocket again. ...I too would be interested in what the action measures at the 12th fret. | ||
| williamfriggle |
Joined: April 2003 Posts: 183 Location: Denver, PA USA | I just adjusted the truss rod last night. I just played her some and looked at it. It is better, but still not where I would like it. Kaman told me to take it to a dealer. But I am going to leave it alone for now and just play her. As I said, it is better. I know I can't make another adjustment. I would have problems. Thanks all, Bill | ||
