Deacon case
Posted 2005-09-14 9:32 AM (#137440)
Subject: Deacon case
Brown Deacon Case
Wonder if the 12 string model would fit this one?
samova
Posted 2005-09-14 10:19 PM (#137441 - in reply to #137440)
Subject: Re: Deacon case
Stephen,this case will not fit the deacon 12.
Bluebird
Posted 2005-09-15 6:35 AM (#137442 - in reply to #137440)
Sam's right. The Preacher/Viper version of this case is interchangable but not the Deacon/Breadwinner.
Wayne
samova
Posted 2005-09-15 11:02 AM (#137443 - in reply to #137440)
Before the 12 string deacon was introduced ovation was using the shorter case with the brown rectangular plastic feet at the bottom of case.When they came out with the 12 string they made the cases slightly londer to fit the 12 string and 6 strings comfortably.The easiest way to tell the cases apart is if it has the brown rectangular plastic feet it fits six string only.If it has the steel ball bearing feet it fits both..
Posted 2005-09-15 1:54 PM (#137444 - in reply to #137440)
Snatched up at a pretty good BIN.
