Cracked tops (not crack pots)
ChatMan
Posted 2005-09-14 12:24 PM (#137434)
Subject: Cracked tops (not crack pots)
August 2004
I have found myself with an a 1981 Legend (A bracing, very interesting boomy tone) that has a cracked top. I also have a 70's Balladeer with finish cracks. So here's my question. Is there a compelling reason to fix either. For these guys, cosmetics are pretty much out of the question, so if I don't do anything for these guitars am I risking that they will deteriorate further. Neither the top crack or the finish cracks seem to be recent.
Posted 2005-09-14 12:39 PM (#137435 - in reply to #137434)
Subject: Re: Cracked tops (not crack pots)
Finish cracks are purely cosmetic. Wood cracks, if stable, aren't a problem. If you can feel the top move when you press on them, then you'll need to get the guitar looked at by an expert.
ChatMan
Posted 2005-09-14 12:44 PM (#137436 - in reply to #137434)
August 2004
If I press on the for real crack I don't feel any movement at all until the splintering sound starts :eek: just kidding. I think it's pretty stable. For $100 I think I'll consider this a test case.
Thanks Paul, you're making an 80's legend believer out of me.
Posted 2005-09-14 1:02 PM (#137437 - in reply to #137434)
At $100, even after paying for repairs, if needed, you're getting a bargain. In NYC you couldn't touch that for less than $450.00.
xnoel
Posted 2005-09-14 1:21 PM (#137438 - in reply to #137434)
I am not a "its gotta look perfect" guy, so a finish crack or even a wood crack is not a big deal for me. Although I won't spend much money in buying a guitar with a problem.
I have had two with wood splits in the top, an 1866 and a 1613. Had the splits stablized just to keep them from going any further. I would suggest you think about doing that.
Of course the guy who does my repair work is very reasonable $100 on the 1866 because he had to take the bridge off and $30 for the classical.
Mitchrx
Posted 2005-09-14 5:15 PM (#137439 - in reply to #137434)
I have an '81 1619 CL with a through the wood crack that goes from the bottom of the bridge to the bottom of the guitar, along the grain. I filled the crack in with super glue. The guitar also has several very minor finish cracks. This is my personal favorite guitar. It sounds great, plays great and appears to be very stable.
I don't think that a professional fix is really worth it, particularly if you can live the the cosmetic issues.
