The Ovation Fan Club | ||
Random quote: "I've always felt that blues, rock 'n' roll and country are just about a beat apart."-Waylon Jennings |
Electronics Upgrade
Forums Archive -> The Vault: 2004-2005 | Message format |
Northcountry |
Joined: February 2004 Posts: 2487 | Hey guy's what numbers would I ask for if I arrange to have my Adamas refitted at the Mother Ship for newer style electronics? I have a fantastic Adamas 1587 that has the three band eq and volume knob. I guess I am looking for the next generation set up that is still designed for the rectangular shape but has the mid shift and shape buttons on it as well. What Say You? Randy | ||
Jeff W. |
Joined: November 2003 Posts: 11039 Location: Earth·SolarSystem·LocalInterstellarCloud·Local Bub | folks love the Optima | ||
Standingovation |
Joined: June 2002 Posts: 6194 Location: Phoenix AZ | OPTIMA. It's my favorite ovation pre-amp, plus it will fit the same hole in your bowl (I think). | ||
Northcountry |
Joined: February 2004 Posts: 2487 | I thought the Optima was the oval shaped pre apm that you can pop out? Anyway if they make this so it fits in the space prvided then Optima it is! Thanks I see Samova is selling some stuff perhaps some lucky soul will be kind enough to buy all of it all and part out some of it to the rest of us? Randy | ||
Jeff W. |
Joined: November 2003 Posts: 11039 Location: Earth·SolarSystem·LocalInterstellarCloud·Local Bub | Randy, All the newest versions of the preamps are rounded. If you don't want to reshape the whole you will need to go for a slightly older version that is still rectangular... | ||
Standingovation |
Joined: June 2002 Posts: 6194 Location: Phoenix AZ | This is Optima: | ||
bauerhillboy |
Joined: February 2004 Posts: 1634 Location: Warren,Pa. | The Optima is essentially an Op50 in a different shaped package, Last time I asked Kim, they hadn't found a way to remove a rectangular preamp and install one of the new shaped ones. They'd have to modify the bowl. Get the Optima. John <>{ | ||
Northcountry |
Joined: February 2004 Posts: 2487 | That's it. OK The Optima. I have never contacted the factory, is there someone I should contact about this? Should I mention The Fan Club (or will this cost me more)? I know I want to try and either take it out on the 30th or perhaps pick it up then. Anyone got a ballpark on the cost for this newer set up. One more silly question will they send me one in the mail and let me install it?? Randy | ||
Jeff W. |
Joined: November 2003 Posts: 11039 Location: Earth·SolarSystem·LocalInterstellarCloud·Local Bub | Call John Budny or Kim Keller at the Service Dept. They shall reveal all. You should mention OFC, but I wouldn't mention Witko's name...they might spit on your Optima. | ||
Standingovation |
Joined: June 2002 Posts: 6194 Location: Phoenix AZ | Originally posted by Jeff W.: Jeff is obviously unaware that I DO spit on my contacts. It's so dry here in AZ that's the only way to get a good connection. they might spit on your Optima. Optima is good and the service department will take good care of you. While you are doing the P/A upgrade I would highly suggest you also have an external battery hatch installed. It'll cost you a 1" x 3/4" piece of lyrachord but well worth the investment. | ||
Jeff W. |
Joined: November 2003 Posts: 11039 Location: Earth·SolarSystem·LocalInterstellarCloud·Local Bub | Originally posted by Standingovation: I DO spit on my contacts. And that's why his contacts at the Service Dept. aren't thrilled to see him.... ....The battery hatch suggestion is a good one. | ||
Northcountry |
Joined: February 2004 Posts: 2487 | Lucky enough I have the battery compartment on mine as well. Just need the newer sounds Man. Thanks guy's I'll call Kim or John and see what this will set me back. Randy | ||
moody, p.i. |
Joined: March 2002 Posts: 15654 Location: SoCal | I'm pretty certain that you can't put the newer oval shaped preamp on a guitar with the older rectangular preamp. I don't believe that the newer one will completely cover the hole left by the old one. | ||
Waskel |
Joined: February 2005 Posts: 11840 Location: closely held secret | Originally posted by moody, p.i.: DUCT TAPE.I'm pretty certain that you can't put the newer oval shaped preamp on a guitar with the older rectangular preamp. I don't believe that the newer one will completely cover the hole left by the old one. | ||
Standingovation |
Joined: June 2002 Posts: 6194 Location: Phoenix AZ | Naw, you leave the old P/A right where it is. Cut a new hole for the new one. Tell people you use one pre-amp for indoor gigs and the other for outdoor. Sometimes for a big stadium concert you may have to use both. It'll really freak them out. Almost like an adamas with 2 walnut knobs that don't attach to anything. Dave | ||
Waskel |
Joined: February 2005 Posts: 11840 Location: closely held secret | Heck, might as well add a couple of those, too. | ||
Charlie Ramon |
Joined: August 2004 Posts: 709 Location: Germany | Randy, last year I replaced the OP24 preamp of my Adamas 1688 to the Optima premp. It fits the same hole but the replacement is not as simple as most people think. The preamps are not 100 percent compatible. If you need more info don't hesitate to contact me. But I think the factory would do a great job! Karl | ||
Northcountry |
Joined: February 2004 Posts: 2487 | Nice Karl. Yep that's what I am after. My 1688 has the original wooden knobs so I would never want to change anything on that one but my later 1587 ( I got from Al) has the deep bowl cutaway and it does have the little battery compartment door as well. I will see what the factory says is the best way to go. If there is some minor mdifications I will be happy to do it myself but if it is fairly involved I will send it home and let mother take care of her. Randy Thanks for all the help guy's! | ||
Ray1986 |
Joined: February 2005 Posts: 4 | Randy, I have done the exact same modification to my 1685 as well as to my 1986 collectors. All you have to do is enlarge the 4 screw holes where the preamp is mounted. Also you'll have to drill a hole in the bowl for the XLR jack. This can be a bit tricky. I decided not to do this, I simply desoldered the XLR jack from the circuit board.(you could always put it back later if you really need it) I hope this helps, good luck. | ||
TexasDoc |
Joined: December 2004 Posts: 1116 Location: Keller, TX | Or, you can send it to Kim Keller and have him do this... | ||
bvince |
Joined: September 2005 Posts: 3618 Location: GATLINBURG TENNESSEE :) | Wow! What did that cost you? | ||
Mitchrx |
Joined: December 2003 Posts: 1071 Location: Carle Place, NY | Originally posted by bvince: Ditto! I'm considering the same thing for my 1537.Wow! What did that cost you? | ||
TexasDoc |
Joined: December 2004 Posts: 1116 Location: Keller, TX | Sorry, don't have an exact price for just the OpPro. Had to get a neck reset and some cosmetic work done on the binding and a dent repaired in the back of the neck. I was going to need to replace all of the electronics anyway, the orig 2-knobber had a short somewhere. It was either this or the Optima (both with XLR). I chose the OpPro. | ||
Buckaroo |
Joined: October 2005 Posts: 400 Location: North Texas | That's one heck of an upgrade. Sanitary to the max. Very impressive guitar. Can it sound as good as it looks? | ||
Standingovation |
Joined: June 2002 Posts: 6194 Location: Phoenix AZ | Hey Big Money, Is that my old guitar? I'm jealous. I want it back !!! Dave | ||
Jump to page : 1 2 Now viewing page 1 [25 messages per page] |
