Something I just found
Posted 2008-12-26 8:11 AM (#5049)
Subject: Something I just found
On the VIP preamp, It seems on mine, you can activate the tuner without the dummy (or regular) 1/4" plug, by just putting your finger on the XLR out on the guitar. It seems the conductivity of your finger, (especially if its a little damp) activates the preamp. I noticed this by accidentally touching the out and saw the light blink on the amp. It's kind of a pain to hold your finger there and pluck the string, but in a pinch, it seems to work. Maybe mine is just a fluke, someone else try this and let us know.
Posted 2008-12-26 8:35 AM (#5050 - in reply to #5049)
Subject: Re: Something I just found
TJ,
Just checked my 1680 and it's the same as yours. The up/down indicators are weak though.
Without the preamp schematic, further experimentation is on hold...
dweezil
Posted 2008-12-26 2:46 PM (#5051 - in reply to #5049)
Also...
Have you noticed that the way saddle seems to be mounted slightly higher on the top E side? Mine is at least... It's like there's a tapered shim under there, but there isn't.
I wonder who many of us here has a 1680?
I adjusted the neck SLIGHTLY and getting really used to it's feel. Going back to a wood top is not going to be easy or pleasant.
Posted 2008-12-26 4:00 PM (#5052 - in reply to #5049)
That would be the "Wet Willie" bypass manuever.
Fascinating.
Posted 2008-12-26 4:04 PM (#5053 - in reply to #5049)
I only know of five on the OFC so far.
Posted 2008-12-26 10:16 PM (#5054 - in reply to #5049)
Fascinating.
Ok Now I've got toclean the keyboarddddd.
The :D dddddddd sticks a little.
PEZ
Posted 2008-12-26 10:51 PM (#5055 - in reply to #5049)
July 2003
Ya really kinda need a good friend to stick it in for ya. Well ...
unless you have 3 arms.
Omaha
Posted 2008-12-26 11:50 PM (#5056 - in reply to #5049)
Yep...I noticed the same thing. On mine, its not really usable, but its true you can cause the pre-amp to flicker on that way.
Posted 2008-12-27 12:25 AM (#5057 - in reply to #5049)
It is possible that sticking a wet pinkie across the three prongs of the XLR may not be good for it...
You are shorting out the system... Just trying to be the voice of sanity.
Posted 2008-12-27 6:14 AM (#5058 - in reply to #5049)
OK, this has gone from a finger that is a little moist from normal humidity in Florida to a finger that has made a trip around the inside of someone's mouth and then spit on. You don't have to get your finger wet to make it work, and I believe it's accomplishing the same thing a 1/4" jack does when it hits the contacts in the jack. I don't think "the company" would design an open jack (xlr) that would damage the system if someone inadvertently touched the prongs. :rolleyes:
Omaha
Posted 2008-12-27 10:04 AM (#5059 - in reply to #5049)
There is zero risk of damage from this. Zip. Zilch. Nada. Nothing.
Posted 2008-12-27 11:23 AM (#5060 - in reply to #5049)
Kind of what I thought , thanks Jeff.
TAFKAR
Posted 2008-12-27 5:19 PM (#5061 - in reply to #5049)
Just wait until your guitar gets a guitar virus and will only play cowboy chords.
MaxBaud
Posted 2008-12-27 6:51 PM (#5062 - in reply to #5049)
November 2008
Not to worry just ship it to me for lifetime storage in my collection! LOL
(more the merryer!! :D )
Posted 2008-12-27 8:15 PM (#5063 - in reply to #5049)
OK, this has gone from a finger that is a little moist from normal humidity in Florida to a finger that has made a trip around the inside of someone's mouth and then spit on.....
Jim,
That is normal humidity for southern Florida. :D
