Low Z - XLR Connection Problems
MRamsey
Posted 2005-12-26 7:47 PM (#124782)
Subject: Low Z - XLR Connection Problems
December 2005
Hello everyone. New member here. I recently purchased a 1998 1869 Custom Legend with Optima Pre-amp. When I plug in the XLR jack, it works but I get crackeling sound with the sound cutting in/out. I suspect I need to look for some loose wires. Any suggestions? Thanks
TexasDoc
Posted 2005-12-26 7:50 PM (#124783 - in reply to #124782)
Subject: Re: Low Z - XLR Connection Problems
To check the preamp: try using the 1/4 inch plug. If it still crackles, it is the preamp. If the 1/4 inch plug works, try a new cable. If that fixes it, it is the cable. If it doesn't, try looking inside at the XLR connector. Check out the connections. Do they look intact?
