OT (potentially): Baritone stringing
jb
Posted 2007-01-28 8:45 AM (#118416)
Subject: OT (potentially): Baritone stringing
Here's a quick question for someone who knows...
If I was looking for occasional use of a baritone-strung guitar (i.e. losing the top string and adding a thicker one on the bottom end), can I simply string an existing guitar (the theory being maybe a Deacon or Breadwinner) that way?
Wasn't sure whether the different tensions etc would stuff the neck, and whether it's a better idea to pick up a relatively inexpensive guitar designed for the purpose.
Cheers, dudes.
JB
Posted 2007-01-28 10:09 AM (#118417 - in reply to #118416)
Subject: Re: OT (potentially): Baritone stringing
Matt Smith does the baritone thing on a standard scale length acoustic by losing the first string of a medium guage set and using a 0.070 for the 6th string. No reason why you couldn't do something similar on a solidbody. You wont do any damage to the neck, though you may need to tweak the neck rod. The cheapo Danelectro baritones are pretty good for the money, and the longer scale helps with big strings and low tension.
BruDeV
Posted 2007-01-28 3:53 PM (#118418 - in reply to #118416)
Also the slots in the nut may need to be widened.
Posted 2007-01-28 10:05 PM (#118419 - in reply to #118416)
That's about it. Let us know how it works out.
Posted 2007-01-28 10:18 PM (#118420 - in reply to #118416)
Did this on a 1112-1 and didn't make any nut adjustments. Makes for an interesting instrument!
jb
Posted 2007-01-29 1:00 PM (#118421 - in reply to #118416)
Cheers, dudes.
I'll be string shopping tomorrow, so I'll see what happens.
JB
Posted 2007-01-29 5:15 PM (#118422 - in reply to #118416)
Right..., like you can buy baritone guitar strings on the Isle of Man. It's just heavy duty fishing line and you know it. You don't fool me.
jb
Posted 2007-01-30 3:34 AM (#118423 - in reply to #118416)
There you go, you see. Prejudice at every turn.
Fishing line is used for standard tuning over here. We use fence wire for the thicker baritone bottom string...
JB
Jacob
Posted 2007-01-30 1:35 PM (#118424 - in reply to #118416)
February 2006
I strung one of my acoustics that way for a while. It worked alright, but trying to get a really low note (even with a .070 or similar) out of a shorter scale length was ultimately unsatisfying.
So then I bought an "inexpensive" baritone.
Then I bought a less inexpensive baritone.
Then another...
Posted 2007-01-30 2:15 PM (#118425 - in reply to #118416)
That is the way it goes.....
