OK, now for the next stupid question....
Posted 2007-02-11 1:49 PM (#115617)
Subject: OK, now for the next stupid question....
To join the rest of the stupid questions I've asked, is there a need to lube tuners now and then? I beleive I have Schaller's (sp) on both my 1614 and the 1681 Adamas. (correct me if I'm wrong) And if so, what do you use?
Jason_S
Posted 2007-02-11 2:09 PM (#115618 - in reply to #115617)
Subject: Re: OK, now for the next stupid question....
ive never lubed any of my machines but i dont see why you cant pull the worm out and hit it with a little graphite or light machine oil...jason
Posted 2007-02-11 3:23 PM (#115619 - in reply to #115617)
I didn't know if they were "life lubricated" which means they die when they run out of lubrication.
Posted 2007-02-11 5:08 PM (#115620 - in reply to #115617)
The answer to your first question is: No
Posted 2007-02-11 8:12 PM (#115621 - in reply to #115617)
Wait till you hear the valves knocking, then add a quart.
Posted 2007-02-11 10:18 PM (#115622 - in reply to #115617)
Just to state the obvious; if they are working fine, fine!
If they are sticking or dragging, a drop of oil shouldn't hurt, if applied carefully. If that don't work, rebuilt/replace.
brainslag
Posted 2007-02-12 9:38 AM (#115623 - in reply to #115617)
Arent your Schallers 'sealed' tuners? The only tuners you should need to oil are the old Klusons with the hole in them(put there for oiling), or opened back ones, or the ones that aren't sealed - they just have a cover over the gear.
Todd G.
Posted 2007-02-12 9:56 AM (#115624 - in reply to #115617)
I would compare these sealed tuners to the CV (constant velocity) joints on car axle shafts. As long as the rubber boot is intact and not torn (keeping the bearings greased), the bearings will last forever (theoretically).
So as long as the seal on the tuner is intact, you shouldn't need to touch it.
