'97 update...need a little help
bauerhillboy
Posted 2007-03-28 4:16 PM (#108224)
Subject: '97 update...need a little help
Things are going well. The hole for the preamp is PERFECT! All it took was patience...and a cordless dremel...and a little skill...and nerve.
I'm working on the dual output now. I have the 2 holes drilled for the jacks. Now I have to figure out how to find the placement of the 2 little screw holes. This may be a no-brainer for some of you, but I can't figure out how to do it. HELP please.
John <>{
Posted 2007-03-28 4:41 PM (#108225 - in reply to #108224)
Subject: Re: '97 update...need a little help
Congrats, John!
I got my initial marks for placement by holding it up to the holes on the inside and eyeballing the position relative to the hole, then I measured off the center of the XLR jack for the actual distance to where the screws go. Does that make any sense?
bauerhillboy
Posted 2007-03-28 4:48 PM (#108226 - in reply to #108224)
It's hard to eyeball much. This is such a little guitar to work on.
But my wife just came home; she's the analytical/mathematical person in the home. I'll see if I can "give" this little problem to her.
Goober
Posted 2007-03-28 8:39 PM (#108227 - in reply to #108224)
January 2004
I really admire you guys that can do this type of work. I don't have the nerve...much less the tools for it.
Posted 2007-03-28 9:58 PM (#108228 - in reply to #108224)
Take some paper and trace the dimensions/placements of the preamp screw holes, then transfer to the bowl but remember to consider any bowl rounding. Good luck!
Jason_S
Posted 2007-03-28 10:18 PM (#108229 - in reply to #108224)
john,rember that the xlr & 1/4 are at a slight angle from one another.....if i can find my calipers ill measure the distance from center of the screw hole to the center of the 1/4 and that should give the corect placement...ill run out ot the shop and look for my calipers jason
