Old amp
slydog
Posted 2007-04-18 3:17 PM (#104872)
Subject: Old amp
April 2005
I ran across an old Kustom amplifier the other day.This thing is well worn........100w 2 channel,reverb,flanger,tube type,2-12" speakers(celestion).Foot switch is broken so it won't change channels.ASking price is $150.00. Are parts still available for this dinosaur? and.......is the price too high? slydog
slydog
Posted 2007-04-18 3:19 PM (#104873 - in reply to #104872)
Subject: Re: Old amp
April 2005
almost forgot........it's in a wood cabinet.
al
Elliot Meldoy
Posted 2007-04-18 3:28 PM (#104874 - in reply to #104872)
April 2007
Is there a model number?
TommyK
Posted 2007-04-18 3:32 PM (#104875 - in reply to #104872)
It's electronc so standard switches, lights, jacks and such should be available. The knobs may not match the original exactly, but if you can get it working, go for it.
Use your nose, sniff around inside the box. If it has a 'burnt' or really heavy 0zone smell (i.e. it's fried), see if he can drop the price by half. If the wires are carmelized(i.e. it's toast), take a walk.
Posted 2007-04-18 3:34 PM (#104876 - in reply to #104872)
tube type?
are you sure?
I don't remember any kustoms being tube unless they were made in the last 10 years
Thanksforallthefish
Posted 2007-04-18 3:41 PM (#104877 - in reply to #104872)
kustom studio 4 valve.. solid wood cab, cane grill, no tuck and roll... there's one currently on the bay as well.
I told him to go for it if it fires up and doesn't smoke after 30 minutes or so at decent volume. he's taking the les paul and the vipertron up to put it through it's paces.
the wood cab and the celestions are worth what he's asking for it.
there's an amp guru down here (Lars) that loves old tube amps..
Glenn
Thanksforallthefish
Posted 2007-04-18 3:54 PM (#104878 - in reply to #104872)
hybrid, ss preamp, tube power,
kustom studio
Glenn
Posted 2007-04-18 4:22 PM (#104879 - in reply to #104872)
I think I would stay away from that one
Posted 2007-04-18 4:52 PM (#104880 - in reply to #104872)
Not a bad deal if it is working and you like the tone. If it needs a rebuild ($200-$300 minimum based on my experience with a good tube amp tech), then you could end up with something that works well for maybe $500. For that price, you should be able to find better equipment.
FlicKreno aka Solid Top
Posted 2007-04-18 6:09 PM (#104881 - in reply to #104872)
An Old Amp. is EXACTLY THAT.....an Old Amp. ,and unless you can fix it yourself,consider carefully if it`s worth it, get an estimate done by a qualified repairman I just finished fixing a PEAVY M 2600 power amp. total cost : purchase price (25 USD) + 2 dollars worth of transistors....now working on a Laney Klipp combo, will have to change : 2 powercaps. + 2 smoothing caps. handfull transistors...if that`s gonna be all then total cost, incl. purchase will be about 80 USD...then a OPERA 415 active Speaker ( that one is problematic ,has an odd distortion )...so you see,unless you know how,or know someone who will do it dirt cheap, Buy New !!,...monthly payments,some performances,skip dinner a couple of times,and you`ll do fine ;)
Vic :cool:
Posted 2007-04-18 6:18 PM (#104882 - in reply to #104872)
What kind of sick SOB are you!!!?!?!?!?
MISS a MEAL?
Not this kid!
I'm looking for that special treat
that fits in between 2PM coffee break
and 'foursies.'
Posted 2007-04-18 6:31 PM (#104883 - in reply to #104872)
Sure,keep up the doughnutrition...
slydog
Posted 2007-04-18 8:44 PM (#104884 - in reply to #104872)
April 2005
I appreciate all the input,all things considered,not sure if I want to mess with this thing..... sly
Posted 2007-04-18 9:27 PM (#104885 - in reply to #104872)
If you were Canadian, you'd understand the cultural importance of Tim Hortons Timbits.
