Question about the VIP
Posted 2007-05-31 8:59 AM (#97661)
Subject: Question about the VIP
I'll be trying out the new VIP electronics during rehearsal tonight and thought I might try the balanced XLR output option. Will I hear any difference? Also, do I need to use the dummy plug in the 1/4 jack while using the XLR option? I think this has previously been covered but I wasn't paying much attention at the time.
John B
Posted 2007-05-31 9:04 AM (#97662 - in reply to #97661)
Subject: Re: Question about the VIP
January 2004
The XLR output on mine has a much hotter signal than the 1/4 jack, plus it's a balanced signal that you can run directly to a PA without a DI. You do not need the "dummy" plug to use the tuner when the XLR is plugged in.
Posted 2007-05-31 9:05 AM (#97663 - in reply to #97661)
Thanks, JohnB. That's the info I was looking for.
Posted 2007-05-31 9:10 AM (#97664 - in reply to #97661)
Now, tell us all about "the Twister" . . .
John B
Posted 2007-05-31 10:48 AM (#97665 - in reply to #97661)
January 2004
Are you sure that story is suitable to post here? It's at least PG-13!
Posted 2007-05-31 11:17 AM (#97666 - in reply to #97661)
True....
As long as you have phantom power from the board AND you are using an XLR cable with pin1 jumped to the shell. Then it works fine.
TexasDoc
Posted 2007-05-31 4:55 PM (#97667 - in reply to #97661)
True....
Exactly. If you don't have the above, the preamp won't be powered on and then you must use the dummy plug to power the preamp and you can still use the XLR.
Posted 2007-05-31 5:55 PM (#97668 - in reply to #97661)
Well, I know there's phantom power coming from the amp, so I'll hook it up and hope for the best. If there is no sound, then I'll use the dummy plug. If that doesn't work, I'll switch to the 1/4" cable, which I know works.
muzza
Posted 2007-05-31 9:19 PM (#97669 - in reply to #97661)
August 2005
Umm.. Do you need to earth the #1 pin at both ends, or just the guitar end?
If it's just the guitar end, wouldn't it be possible to make that connection inside the guitar, at the jack? Therefore, the cable's earthing configuration would be irrelevant.
Seems simple, but am I missing something?
noah
Posted 2007-06-01 2:15 AM (#97670 - in reply to #97661)
Not at both ends... if you have to modify your own cable, ONLY jump pin1 to the shell on the guitar-end of the cable.
The XLR swivel-end Planet Waves cables are pin1-to-shell. There were other brands off the shelf that other members mentioned. Check the archives.
Oh... did I mention that if you make your own, ONLY jump pin1 to the shell on the guitar-end of the cable.
muzza
Posted 2007-06-01 2:56 AM (#97671 - in reply to #97661)
August 2005
So...
...why not just do a bit of DIY soldering and jump pin 1 to ground inside the guitar?
Wouldn't that negate the need for a special cable?
Posted 2007-06-01 7:10 AM (#97672 - in reply to #97661)
Because it's inside a sealed jack mounted on a circuit board... and would probably void your warranty.
noah
Posted 2007-06-01 7:11 AM (#97673 - in reply to #97661)
Murray, The XLR and 1/4 inch are mounted on a circuit board. I looked at a spare for an OP-Pro. The circuit traces are right there. That would be too easy to be the solution. My first thought is that it would put the battery online all the time... just like leaving the guitar plugged in and running down the battery? I'm content with the Planet Waves cable.
Posted 2007-06-01 9:49 AM (#97674 - in reply to #97661)
True....As long as you have phantom power from the board AND you are using an XLR cable with pin1 jumped to the shell. Then it works fine.
I have little idea what you all are talking about here, but I must presume that pin1 wasn't jumping to the shell of my XLR cable because the phantom power from the amp did not power the preamp. I had to use the dummy plug, but not until after changing the battery. I'll pick up another cable with the jumping feature later today and try again. I'm using the same set-up tonight, so I'd like to get these bugs worked out sooner than later. Incidently, I'm using the Koala guitar and boy does it sound great. The VIP preamp is remarkable. Anybody know what specific mic models were used in the digital imaging presets? After experimenting briefly, I chose to use preset 1 with a mix of half preset/half pickup. Since tonight's solo gig is at an art gallery, the patrons should appreciate the Koala guitar as much as the rest of the art hanging on the walls.
ChatMan
Posted 2007-06-01 9:50 AM (#97675 - in reply to #97661)
August 2004
For a variety of reasons, you only want a single place where all the grounds are connected (a technique commonly obfuscated by calling it a single point ground). Connecting the two inside the guitar would make this a permanent configuratoin. There may be cases where you want both of your signal wires isolated from the shield. I haven't seen any circuit diagrams of XLR equipped preamps but am somewhat puzzled as to why this particular configuration is necessary. I'm guessing it's because the preamp is sourced from a third party and so complete design control over manufacturing isn't possible. Then again, might just not have occurred to anyone until after the production was completed and so now this is considered a 'design feature' ;)
Barring any other choice, and assuming the the ability to isolate the signal waires from the shield is sometimes necessary, I'd think a switch by the XLR (or in the can) would make more sense.
(Editted cause I can never got something right the first time :rolleyes: )
