Yet another question for the experts.
Posted 2007-07-08 4:19 PM (#91009)
Subject: Yet another question for the experts.
On my 06 KOA, the high E string sounds a bit muted when played open. When played in any position on the fret board, it sounds a lot livelier. Could this be something with the nut or the cut in the nut? I've tried different gauge strings, but the same effect. I was thinking maybe the nut grove is higher on the tuner side making the rest of the grove mute the string. Do I send it back, or is this an easy fix?
Elliot Meldoy
Posted 2007-07-08 4:40 PM (#91010 - in reply to #91009)
Subject: Re: Yet another question for the experts.
April 2007
That could be one possibility.
Does it have 5the same effect with a higher gauge string? also check and see if the string isn't just barely buzzing the first fret.
Posted 2007-07-08 4:54 PM (#91011 - in reply to #91009)
Same effect with 010 and 012. No buzz that I can detect. It really sounds like when I wipe the fretboard after playing, and a little fuzz ends up on the string from the rag which I've had happen before.
Posted 2007-07-08 5:00 PM (#91012 - in reply to #91009)
Here's a quick way to find out if it's the nut. Take the string out of the nut-slot and place it between the 1st and 2nd string slots, resting on the top of the nut. Bring it up to pitch and if the tone improves you need to recut the nut-slot.
Posted 2007-07-08 5:44 PM (#91013 - in reply to #91009)
Thanks Paul, I tried that too and it seems the same. I just took the strings off and added a shim under the saddle, no difference. Man, I have no clue as to what is causing this. Like I said, if you fret it anywhere on the board, it sounds fine. Just open it sounds dead which would indicate to me it has something to do with the nut. I took a dentist pick and cleaned out the groove (looks like there was some rough area in there) and, to quote Bob Seger, it's "still the same". :confused:
BruDeV
Posted 2007-07-08 5:48 PM (#91014 - in reply to #91009)
Look to see if there's a gap between the nut and the peghead. Maybe that side of the nut is not flush with the neck.
Posted 2007-07-08 6:16 PM (#91015 - in reply to #91009)
I always found that was caused by a but cut on the nut slot.
Posted 2007-07-08 6:25 PM (#91016 - in reply to #91009)
but cut?? splain please...
Posted 2007-07-08 10:10 PM (#91017 - in reply to #91009)
Bad cut! As in what the local Wal-Mart Beautician did to my wife's hair a week ago...ever seen an angry Russian woman? Not Pretty! And, sounds like your nut cut isn't either! (is it just me or do we need a PG rating now...lol) :eek:
BTW TJ, try just a bit of graphite (pencil lead will do)
Blessings...
Sleepy Eyes McGee
Posted 2007-07-08 11:12 PM (#91018 - in reply to #91009)
June 2005
I had something similiar with my Adamas 12 awhile back. Both open E's sounded dead but fretting anything else sounded fine. Turns out the saddle on the bridge was crushed underneath so I changed out the bridge piece and made a huge improvement.
willard
Posted 2007-07-09 6:52 AM (#91019 - in reply to #91009)
My B string is the same on my Legend. I had the nut worked on and it seems a little better but still sounds a bit dead when played open. I'm anxious to hear what you find.
Posted 2007-07-09 9:00 AM (#91020 - in reply to #91009)
None of my Celebrity's have this problem :p
[Sorry, I couldn't resist... forgive me :rolleyes: ]
Posted 2007-07-09 9:04 AM (#91021 - in reply to #91009)
BAD cut. Comes from not having enough break-angle. The old 14* pegheads rearely had this.
There is probably a high spot in the trench of the slot somewhere. You want the high spot to be at the back edge next to the fretboard.
Paul Blanchard
Posted 2007-07-09 11:09 AM (#91022 - in reply to #91009)
I have found that on numerous guitars I have had come through here. I take them to my tech, who makes a bit of paste from bone dust and epoxy and puts a tiny bit in the nut slot to build it up. It dries fast and can easily be correctly filed. That has always solved the problem. This doesn't mean it's the problem with yours, because Temp's diagnostic test should have revealed it. (It's easier than replacing the nut.)
Posted 2007-07-09 11:27 AM (#91023 - in reply to #91009)
I have adopted the leetle tube of Porcelain Repair mixed with the abrasive dust of whatever nut is under repair. For the Black Tusq I use superglue.
Posted 2007-07-09 2:30 PM (#91024 - in reply to #91009)
I put an email in to JB as this is under warranty and I don't want to start messing with the nut. I'll see what he says.
Posted 2007-07-09 7:43 PM (#91025 - in reply to #91009)
Jim, basic set-up work like this is worth learning how to do yourself. Before you get into warranties and shipping your guitar ask John to send you a couple of nuts. Then you can try recutting the slot yourself. That way if you screw-up at least you have a replacement. A cheap X-Acto razor saw with the tooth-set flattened will do a decent job of cutting a slot for an unwound string.
luthier444
Posted 2007-07-09 9:12 PM (#91026 - in reply to #91009)
sounds like bad nut either way... Filed to hard headstock or to hard fb.. Also a bad string maybe.. I hate it when production bends strings!!!!!!!!! But that usually buzzes all the way up..
