Nut & Saddle Material
keven
Posted 2007-09-17 5:36 PM (#81443)
Subject: Nut & Saddle Material
What is the material used on Ovations for the Nut & Saddle? Is it plastic/tusq/bone or something else? I'm certain the nut & saddle material on the Applause's that I owned were made of plastic. It may be different for different models but that info isn't advertised very much...
thanks in advance for any news on this subject.
later...
Posted 2007-09-17 5:40 PM (#81444 - in reply to #81443)
Subject: Re: Nut & Saddle Material
SpaceAge Acrylic.
Posted 2007-09-17 5:45 PM (#81445 - in reply to #81443)
The Answer is:
Seminiferous tubules and Leather
Posted 2007-09-17 5:47 PM (#81446 - in reply to #81443)
... oh, "O-VAY-shun!"
Posted 2007-09-17 6:28 PM (#81447 - in reply to #81443)
Oy vay shun! (for our Jewish members)
FlicKreno aka Solid Top
Posted 2007-09-17 6:49 PM (#81448 - in reply to #81443)
Originally posted by cliff:
SpaceAge Acrylic.
...and as allways Cliff is Right.. :)
Vic
..probably plays banjo`s as well..
Posted 2007-09-17 7:11 PM (#81449 - in reply to #81443)
The nuts on Adamas and higher end USA Ovations are bone. The synthetic nuts on USA guitars are made from a polymer called Delrin (also know as Celcon)
Posted 2007-09-17 9:05 PM (#81450 - in reply to #81443)
Paul, welcome back. We missed you. Hope your move went well.
Posted 2007-09-17 9:12 PM (#81451 - in reply to #81443)
"Hope your move went well." +1
And, to take this question a step further, would the average player hear a noticable difference in replacing the Delrin nut with a bone nut?
Posted 2007-09-17 10:36 PM (#81452 - in reply to #81443)
Yeah, what Paul said. The bone sound better.
Posted 2007-09-18 12:37 AM (#81453 - in reply to #81443)
Naw... But you might FEEL better about it.
Posted 2007-09-18 10:18 AM (#81454 - in reply to #81443)
True, However you would probably hear a bone saddle more. Harder material passes more vibrations to and through the top. The nut only works when it's an open string. Bone tends to wear better over the years whereas the Delrin and get cut down from the strings sawing them over the years. Unless you use the special Nut adapted string tubes.
Posted 2007-09-18 11:43 AM (#81455 - in reply to #81443)
Is there a factory replacement bone or tusq saddle? The daughter's Elite T saddle is getting groovy. It's been a while since I've looked at it, but isn't the pickup glued to the bottom of the saddle?
Posted 2007-09-18 11:52 AM (#81456 - in reply to #81443)
Anybody ever tried the LeadPencil approach..??..
Vic
..I will eventually replace the nuts on my O`s with Tusque Nuts..
Posted 2007-09-18 11:59 AM (#81457 - in reply to #81443)
There are handmade bone and ceramic saddles for the Ovation pickup but they are not cheap, and whether the very slight improvement in tone is worth the extra dough is debateable. On the older pickups you can just peel off the plastic saddle molding and sit a new one on the silicone. Not sure about the latest versions.
keven
Posted 2007-09-18 6:53 PM (#81458 - in reply to #81443)
Replacement Ovation nut:
TUSQ PQ-6114-00
I saw it on E-bay...
The Ovation saddle that I've being working with, seems a bit non-standard?
length - width - height
2 3/4" x 9/32" x TBD
compensated bridge at both E strings
a replacement saddle may require using a Bone/Tusq Blank and going from there.
later... :cool:
maxdaddy7271
Posted 2007-09-26 5:28 AM (#81459 - in reply to #81443)
March 2006
No more lead pencils. Graphite nuts!
Steve
Posted 2007-09-26 8:53 AM (#81460 - in reply to #81443)
July 2002
How about fossilized ivory? Probably too expensive for a slight improvement?....
Posted 2007-09-26 10:02 AM (#81461 - in reply to #81443)
The main factors in nut and saddle materials are weight, density and hardness. Materials that are light and dense sound best. Bone and ivory are ideal but the difference between bone and ivory in terms of density is hardly worth considering, given that bone is a whole lot cheaper and easier to get hold of.
Posted 2007-09-26 11:04 AM (#81462 - in reply to #81443)
That's why Whitehead only dates long-legged women . . . "Higher Yield".
Posted 2007-09-26 9:02 PM (#81463 - in reply to #81443)
Damn straight...
Posted 2007-09-26 9:24 PM (#81464 - in reply to #81443)
femurs usually ARE . . .
