The Ovation Fan Club | ||
Random quote: "One good thing about music, when it hits you, you feel no pain." - Bob Marley |
Pandora II- The GCDB Restoration
seesquare |
Joined: November 2002 Posts: 3603 Location: Pacific Northwest Inland Empire | "Only Hope remained there in an unbreakable home within under the rim of the great jar, and did not fly out at the door; for ere that, the lid of the jar stopped her, by the will of Aegis-holding Zeus who gathers the clouds." So, releasing the evils from the container, and maintaining the prospect of beauty & grace. I have some work to do. I have given the guitar a cursory examination. It appears to be functional, in its present state, and will require adjustments to the playability. The strings are pretty dead, though the instrument has quite a bit of punch & depth, though presently a bit muddy in the bass end. The highs are clear. Sustain is pretty good. The nut has been replaced & there is a compensated saddle in the bridge. The neck fills my hand real well, and there are no cracks. The peghead still has both ears intact. Everything needs a good scrubbing- tuners & fretboard, especially. As I surmised, the paint is awful, and the binding is a mess. The bridge appears sound, and will need a bit of paint removal, also. First plan of action is to scrape off all that paint & see what the top looks like. The upper, bass end of the x-brace is loose, but everything else is secure. It looks like the MOP from the rosette is still on the guitar, so there needs to be a plan for the soundhole decoration. It looks like the rosette was recessed into the top, also. So Paul, I may be able to save the top. That will be a major coup. And Dave, you were correct. It is x-braced. With the A-918 serial #, the guitar was apparently made in late 1968. Okay, so a few images to start this saga: (1127 front view- smaller image.jpg) (back view- smaller image.jpg) (label 1.jpg) (scraped top with binding pattern- small image.jpg) Attachments ---------------- 1127 front view- smaller image.jpg (87KB - 1 downloads) back view- smaller image.jpg (84KB - 0 downloads) label 1.jpg (81KB - 1 downloads) scraped top with binding pattern- small image.jpg (82KB - 1 downloads) | ||
Standingovation |
Joined: June 2002 Posts: 6192 Location: Phoenix AZ | Good luck Chris. Can't wait to see how this turns out. I meant to send you a new rosette for it, but mistakenly sent it to another member who has offered to forward it to you. Small cosmetic improvement, but I guess every little bit helps. Keep us posted. | ||
seesquare |
Joined: November 2002 Posts: 3603 Location: Pacific Northwest Inland Empire | I shall! And our generous fellow compatriot has contacted me. Thanks, Al! I will need all the help I can get. It is inherently a fine instrument, and deserves refurbishment. It has seen a long life, and its playability was maintained. I think it was gigged a long time. There is a name on the folded paper, used as a shim under the saddle, which I will pursue further. What are the suggestions for that torn label? Should I just varnish it in place, or attempt to replace it? | ||
seesquare |
Joined: November 2002 Posts: 3603 Location: Pacific Northwest Inland Empire | Sent a request to GEWA about a graphic file for an age-appropriate paper label, since they have the legal rights to Ovation copyright and materials. See what develops from that. I have a date with my cabinet scraper, probably extend into next week. Lotta nasty blue paint to remove. The lacquer thinner and citrus remover options look messy and tedious. Then, make some serious decisions about soundboard and neck angle issues. I think the neck may need to come off to install the replacement rosette, unless someone has clever means to accomplish the task, without major surgery. | ||
moody, p.i. |
Joined: March 2002 Posts: 15654 Location: SoCal | If it was built in late 68, then it was probably one of the very early GCDB's. I believe in an older thread here we postulated (with Beal's help) that there were maybe 50 built all total. A really wonderful guitar with a short run at the factory..... | ||
Love O Fair |
Joined: February 2016 Posts: 1770 Location: When?? | @seesquare - >>>What are the suggestions for that torn label?<<< Hopefully GEWA will participate. If not, then perhaps a suitable duplicate can be made using your own graphic platform and printer. Then there is always DaveKell if you want something custom to represent the project-- as in the very cool "BBurg" label he made for Bernie's Viper creation. Does the autograph signature on the top appear as anyone we may recognize? Edited by Love O Fair 2022-01-08 3:27 PM | ||
seesquare |
Joined: November 2002 Posts: 3603 Location: Pacific Northwest Inland Empire | That signature is illegible to me. And, it isn’t even close to the name on the saddle shim. So, just someone’s self-expression. The tuners get a good cleaning next. Really funky. | ||
seesquare |
Joined: November 2002 Posts: 3603 Location: Pacific Northwest Inland Empire | The tuners have been cleaned. A question for conjectural analysis. What is the optimal lubricant for repacking the gears? Got a supply of Vaseline, but wondered if there was something better. (tuners 3- smaller image.jpg) (clean tuner parts 2- smaller image.jpg) (clean tuner parts 1- smaller image.jpg) Attachments ---------------- tuners 3- smaller image.jpg (60KB - 0 downloads) clean tuner parts 2- smaller image.jpg (92KB - 0 downloads) clean tuner parts 1- smaller image.jpg (74KB - 0 downloads) | ||
FlySig |
Joined: October 2005 Posts: 4026 Location: Utah | seesquare - 2022-01-09 12:27 PM The tuners have been cleaned. A question for conjectural analysis. What is the optimal lubricant for repacking the gears? Got a supply of Vaseline, but wondered if there was something better. Just an amateur opinion, but I'd use a very tiny amount of gun grease. Oils eventually evaporate. Gun greases seem to stay in place for a long time. Use as little as possible. Shooter's Choice makes a good grease in a syringe style applicator. Another option is a food grade lithium grease. This is what I use on my guns because it works and it is cheaper than gun-specific products. You can probably get away with no lube at all. idk. | ||
DanSavage |
Joined: June 2012 Posts: 2303 Location: Lake Forest, CA | seesquare - 2022-01-08 11:50 AM I think the neck may need to come off to install the replacement rosette, unless someone has clever means to accomplish the task, without major surgery. If you are using a rosette with a raised one, I've replaced them with the neck installed several times. If you're inlaying one, then that's going to be a bit more trouble. | ||
seesquare |
Joined: November 2002 Posts: 3603 Location: Pacific Northwest Inland Empire | Thanks for the input! I just figured, since the tuners come lubricated, I will repack them with some type of lubricant. How about some aerosol silicone? Doesn’t constitute much mass, but has great slippery properties. And it will get inside the tuner housing pretty well. Doesn’t attract dirt, either. | ||
seesquare |
Joined: November 2002 Posts: 3603 Location: Pacific Northwest Inland Empire | Thanks Dan. I will play it by ear for now. Will have to evaluate my options, as this project progresses. I’m just not relishing the idea of pulling the neck, if I don’t have to. Kinda depends on what I find after scraping the top. | ||
Love O Fair |
Joined: February 2016 Posts: 1770 Location: When?? | +1 on the Shooter's Choice with the injector. A little dab'll do ya and it's great stuff to have around for other uses as well. | ||
seesquare |
Joined: November 2002 Posts: 3603 Location: Pacific Northwest Inland Empire | Thanks for the suggestion and product endorsement. I will put it on my shopping list. | ||
seesquare |
Joined: November 2002 Posts: 3603 Location: Pacific Northwest Inland Empire | Well, at least the tuners are looking better. (finished tuners 1- smaller image.jpg) (finished tuners 4- smaller image.jpg) Attachments ---------------- finished tuners 1- smaller image.jpg (86KB - 0 downloads) finished tuners 4- smaller image.jpg (66KB - 0 downloads) | ||
moody, p.i. |
Joined: March 2002 Posts: 15654 Location: SoCal | Heck, you practically have the entire guitar done! | ||
seesquare |
Joined: November 2002 Posts: 3603 Location: Pacific Northwest Inland Empire | Thanks for the optimism, Paul. My date with the scraper is arriving soon. Perhaps, in the current set of expectations, I also need to construct a long-throat clamp for that fissure below the bridge. Needs to be about a foot long to reach the end of the body. Heck, probably gonna need one about 9 inches, too. Gots lots of 3/4-inch square tube laying around from all my pedalcraft fabrications- piece-o'-cake. | ||
seesquare |
Joined: November 2002 Posts: 3603 Location: Pacific Northwest Inland Empire | Got a response from Ovation Customer Service. No label graphics available. They gave me some interesting history, related to that issue, also. "Additionally, in the mid/late 1990's, in the early days of internet sales and businesses selling online, we discovered a large quantity of counterfeit guitars being offered for sale-coupled with weekly calls for "replacement" labels and headstock appliques that we decided we would not produce or provide reprints for any requests for these "parts" as it was obvious to us that most of the requests were to correct these counterfeit guitars." So, the search will continue. | ||
Old Man Arthur |
Joined: September 2006 Posts: 10777 Location: Keepin' It Weird in Portland, OR | Yeah.... Bullshit. Because during THIS century, John Budny send me stickers and tuners and saddles and preamps (no rosettes). Did you tell them that you probably know more about Ovation history than they do? | ||
BCam |
Joined: October 2014 Posts: 268 | He sent me a rosette. | ||
seesquare |
Joined: November 2002 Posts: 3603 Location: Pacific Northwest Inland Empire | I understand what “not available “ means. Whether the current support crew is accurate or even motivated is conjecture, at best. As Blanche DuBois opined, “I depend on the kindness of strangers.” | ||
Old Man Arthur |
Joined: September 2006 Posts: 10777 Location: Keepin' It Weird in Portland, OR | Yeah. I am not trying to be rude to them. They probably just don't HAVE all of the stuff that JB had. Sadly, a bunch of stuff went into that dumpster. | ||
seesquare |
Joined: November 2002 Posts: 3603 Location: Pacific Northwest Inland Empire | S'OK. Jonmark is probably right, "We are nerds". Albeit, passionate & devoted. The world keeps spinnin' & times (and resources) change. I don't need to ask often if we're having fun, yet. That's cool. | ||
Patch |
Joined: May 2006 Posts: 4221 Location: Steeler Nation, Hudson Valley Contingent | Yep! Gonna be checking in on this one regularly.... Apparently I'm a nerd too. | ||
seesquare |
Joined: November 2002 Posts: 3603 Location: Pacific Northwest Inland Empire | Thanks for swelling the gallery, Patch! This is going to be a cooperative enterprise, & any conjecture, wild guesses, or ***-forbid, real science & accurate facts, are welcomed & expected. I will be the chief-cook-&-bottlewasher & attempt to cobble together a decent restoration of the GCDB. So then, more progress. Got the top scraped & found several areas in need of significant repair. Answered a few of the prior concerns, i.e., the rosette was inlaid in the soundboard, and there was no repair to the top, before that awful blue goo was slathered onto the soundboard. Actually, I am fortunate Ovation put a thick epoxy topcoat on their instruments. The paint removal required a little less, let's term it "precision", to accomplish the task. I have discovered the binding was lost at the bottom of the guitar, and based on the backlighted photo, it appears there is no kerfing in that vicinity, though a lot of (probably epoxy) filler was used to secure the bottom edge of the soundboard to the bowl. That may be a challenge to remedy, after the top is cleated & flattened, since there won't be anything to reglue the top to, or glue the replacement binding onto. OK, enough already. Here's some current photos: (Scaping- treble side- smaller image.jpg) (Scraped top 1- smaller image.jpg) (scraped soundhole- smaller image.jpg) (scraped fissure- smaller image.jpg) (lighted fissure 3- smaller image.jpg) Attachments ---------------- Scaping- treble side- smaller image.jpg (92KB - 0 downloads) Scraped top 1- smaller image.jpg (86KB - 0 downloads) scraped soundhole- smaller image.jpg (67KB - 0 downloads) scraped fissure- smaller image.jpg (88KB - 0 downloads) lighted fissure 3- smaller image.jpg (55KB - 0 downloads) | ||
Jump to page : < 1 2 3 4 5 6 ... > Now viewing page 1 [25 messages per page] |
