1/4 plug disintegrates inside effects output jack
| ProfessorBB |
Joined: January 2006 Posts: 5881 Location: Colorado Rocky Mountains | While setting up for rehearsal last night, I pulled a patch cord out of one of the effects pedals and discovered the tip of the 1/4 plug was still inside the output jack with no apparent way for convenient extraction. Since the tip was connected to the plug shaft by pressure, I jammed the plug back into the output and apparently managed to remake a connection as it worked fine. Any ideas on how to remove the plug tip short of pulling the unit apart? Maybe some jeweler’s needle nose pliers? | ||
| cliff |
Joined: March 2002 Posts: 14842 Location: NJ | straight, long-nosed roach-clip (uh, . . I mean hemostat). | ||
| cliff |
Joined: March 2002 Posts: 14842 Location: NJ | . . . or get Pamela to suck it out. | ||
| Old Man Arthur |
Joined: September 2006 Posts: 10777 Location: Keepin' It Weird in Portland, OR | Aw Professor, Sorry. But you have listed you two choices. If you can see inside the hollow-part of the jack-pin, mebbe you can stick a small screwdriver tip in there, tilt for tension, and pull. Good Luck! | ||
| cliff |
Joined: March 2002 Posts: 14842 Location: NJ | Is it THAT hard t'open up the pedal?? | ||
| Old Man Arthur |
Joined: September 2006 Posts: 10777 Location: Keepin' It Weird in Portland, OR | Originally posted by cliff: Play nice! I wouldn't wanna open my Zoom G1X.Is it THAT hard t'open up the pedal?? | ||
| Jeff W. |
Joined: November 2003 Posts: 11039 Location: Earth·SolarSystem·LocalInterstellarCloud·Local Bub | step fast and hard onto the pedal | ||
| ProfessorBB |
Joined: January 2006 Posts: 5881 Location: Colorado Rocky Mountains | The pedal is a Digitech multi, not one of those nice small Boss units. I can see lots of small electronic thingies jumping out and disappearing behind the work bech as I split the cases, so I'll open it up only as a last resort. Old Man, that's a great idea about the screwdriver. Also, what about dabbing a little super glue on the cable now protruding about 1/16" out of the end of the 1/4 plug and jamming it back into the tip, assuming I use it sparingly and don't make a mess out of the jack's internals? | ||
| an4340 |
Joined: May 2003 Posts: 4389 Location: Capital District, NY, USA Minor Outlying Islands | It might be worth opening, just to see what's inside. | ||
| alpep |
Joined: December 2001 Posts: 10583 Location: NJ | take a pair of needle nose pliers and jam them inside of what is left of the tip of the jack. open the handles and apply pressure and pull outward. say a prayer or two. didn't work? take a soldering tool with a 90 degree tip and insert it and then try to pull it outwards. or maybe a dental pick. again say a few prayers for spiritual guidance and that you don't crack the cheapo plastic that everything is made out of these days. most likely the jacks on that pedal as closed and you will not be able to force it out from the other end. if you can't get it out then you have to replace it. | ||
| cliff |
Joined: March 2002 Posts: 14842 Location: NJ | You guys have no Sense of Adventure. The FIRST thing I do when I get a new toy is to take it apart t'see what makes it "tick" . . . (btw; anyone know the time?? . . my watch doesn't seem t'be working . . .) | ||
| an4340 |
Joined: May 2003 Posts: 4389 Location: Capital District, NY, USA Minor Outlying Islands | Probably a dead battery. I've taken the backs off my watches, but I'ven't mucked around inside. Each post gives a time check when posted. | ||
| cliff |
| Weaser P |
Joined: October 2005 Posts: 5332 Location: Bluffton, SC | :D :D | ||
| FlicKreno aka Solid Top |
Joined: April 2006 Posts: 2491 Location: Copenhagen Denmark | Professor BB, my respect for ya`has dwindled,..a ZOOM..??..get one o`those thingies "made in HongKong"..dont`cha know that all the good stuff is bein`made there.. :) There should be a shaft connected to that tip,where the cable was soldered onto..sounds as if that shaft is broken,if it is,than that output jack may have been damaged..replace that output jack,no short-cuts here I`m afraid.. :) Vic ..You can get it if you really want it.. ..but you must try,try and try.. ..you`ll succeed when you try.. | ||
| ProfessorBB |
Joined: January 2006 Posts: 5881 Location: Colorado Rocky Mountains | Vic, I'm not sure I understand your post, particularly about the Zoom. The Zoom is fine. This is a Digitech, and it, too, seems to be fine. It is the cable that failed. What remains inside the output jack is the tip of the 1/4" plug. It is being held in by the jack's tip detents. This silly cable was a cheap 12 incher supplied with a pedal board kit. It does look like the cable shaft failed at the solder point. | ||
Joined: April 2006 Posts: 2491 Location: Copenhagen Denmark | Prof BB, I was just Kiddin` ya` ,the ZOOM and DIGITECH are Fine pieces of equipment, that what happened is one of those freak incidents, but seriously, if it broke at the solderjoint than the shaft should be sticking out of the jack-out, if it does not, is it still in the jack-sleeve ?,.when shaking that box, can you hear something rattling..?..what model is it ? Vic | ||
| ProfessorBB |
Joined: January 2006 Posts: 5881 Location: Colorado Rocky Mountains | Problem resolved. I exerted extra pressure in jamming the plug into the jack, then slowly and carefully extracted it hoping to keep the tip intact. It worked. The tip came out. The cable failed where the tip is soldered to the short cable end protruding from the plug shaft just beyond the plastic gasket ring. | ||
| alpep |
Joined: December 2001 Posts: 10583 Location: NJ | brad I have shortie monster cables in stock if you need them for effect to effect | ||
