Guidance on a Bowl Bend on a 1974 Custom Balladeer
sycamore
Posted 2021-05-24 4:27 AM (#555587 - in reply to #554967)
Subject: Re: Guidance on a Bowl Bend on a 1974 Custom Balladeer
March 2007
seesquare - 2021-01-30 11:12 PM
RE: bowl bend protocol, as outlined above:
That pedantic style sure sounds like something I would write. I did a bowl bend on an 1113 Classical several years ago, & it had the hand-laid fiberglass bowl, which probably made the adjustment more feasible.
The method above is generally accurate. Above all, go slow. It won't take much angle change to make a big difference. Making the bowl-holding jig will be the biggest challenge. If you want to take a general shot at whether the bowl will bend, just put a bungee cord on the peghead & tail strap button, & let it sit for a few days. If the neck takes a different "set", after the tension is removed, & left to it's own device for a day, you just might be in business.
Best of luck!
just to clarify the bungee cord method: is it like this?
(Bowl Bend.jpg)
Attachments Bowl Bend.jpg (47KB - 0 downloads)
sycamore
Posted 2021-05-24 7:02 AM (#555588 - in reply to #554934)
Subject: RE: Guidance on a Bowl Bend on a 1974 Custom Balladeer
March 2007
OK, after a beautiful 33-year relationship, this baby will now bend to my will. what do you think of my jig? A glass garden table and some luggage straps, books to keep the body from tilting. A pencil mark on the mitre block showes my starting point.
I was thinking about the various arrangements for supporting the round back and then I thought "the front is not round".
Now cooling, with fingers and toes crossed.
Does anyone have a protocol for bowl unbending?
Edited by sycamore 2021-05-24 7:03 AM
Posted 2021-05-24 11:36 AM (#555589 - in reply to #554934)
Take a look at this album and see what I did.
Photo albums (ovationfanclub.com)
 This is all you need.
Edited by MWoody 2021-05-24 11:40 AM
DanSavage
Posted 2021-05-24 6:38 PM (#555590 - in reply to #555588)
June 2012
sycamore - 2021-05-24 5:02 AM
A glass garden table...
I would be careful not to overheat the glass lest it shatter.
sycamore
Posted 2021-05-25 4:55 AM (#555592 - in reply to #555590)
March 2007
Good advice, thanks.
Alternatively, I could set the kitchen table on fire...
(Bowl Bend 2.jpg)
Attachments Bowl Bend 2.jpg (29KB - 0 downloads)
DanSavage
Posted 2021-05-25 11:41 AM (#555593 - in reply to #555592)
June 2012
I should also add that you can only perform bowl bend on a cloth bowl.
SMC bowls can't be re-shaped.
sycamore
Posted 2021-06-18 6:14 AM (#555740 - in reply to #554934)
March 2007
Mine went OK. It did not bend as much as I thought but I've decided it's enough. I am still tuning it a semitone flat and the action is very acceptable now.
