The Ovation Fan Club | ||
Random quote: "I've always felt that blues, rock 'n' roll and country are just about a beat apart."-Waylon Jennings |
DanSavage![]() |
Joined: June 2012 Posts: 2332 Location: Pueblo West, CO | I was talking to the worship leader about bringing in my 1655 and he said it would be cool.
Once I get this job done, I still need to decide whether to leave the guitar strung in Rickenbacker style or revert it back to standard stringing. I'll break out my Yamaha 12-string which is standard, then play it again to hear how different it sounds when strummed.
2wheeldrummer![]() |
Joined: February 2014 Posts: 714 Location: moline,illinois | Nice job on the battery box Dan! Screws and epoxy guess they wanted to make sure it would stay tight. It looks like you've got it whipped let this be a reminder to the rest of us on tightening bolts. | ||
Old Man Arthur![]() |
Joined: September 2006 Posts: 10777 Location: Keepin' It Weird in Portland, OR | Screws and Glue. Pants and Suspenders. When you want to be SURE nothing is moving. ![]() | ||
standing![]() |
Joined: December 2008 Posts: 1454 Location: Texas | Dan, Did you set it up “Ric style” yourself, or did you inherit that setup? | ||
DanSavage![]() |
Joined: June 2012 Posts: 2332 Location: Pueblo West, CO | Thanks, everyone. Using it, I found that I had soldered the hot wire for the new output jack to the wrong lug. Once I re-soldered it to the correct lug, everything worked fine. So, I buttoned up the pre-amp and re-installed everything. Phew! I decided to string it up using standard 12-string tuning. I played it last night and I think I'll keep it this way for a while. I do like the sound of the analog pre-amp. | ||
DanSavage![]() |
Joined: June 2012 Posts: 2332 Location: Pueblo West, CO | standing - 2020-03-08 2:17 PM Dan, Did you set it up “Ric style” yourself, or did you inherit that setup? Yes, I set it up with Ric-style tuning a year or so ago. I like it. It still has the ring of a 12-string, but the sound of the octave strings is a little more muted compared to standard tuning. As I wrote above, I restrung it to standard. I'll keep it this way for now. | ||
arumako![]() |
Joined: October 2012 Posts: 1078 Location: Yokohama, Japan | Nice project, Dan. It looks like you left the bolt that holds the original battery case as is. Did you secure it at all? The black compensated saddle looks great too. Thanks for sharing. | ||
Tom The Piddler![]() |
Joined: March 2019 Posts: 26 Location: Cass County, Texas | DanSavage - 2020-03-09 1:07 PM standing - 2020-03-08 2:17 PM Dan, Did you set it up “Ric style” yourself, or did you inherit that setup? Yes, I set it up with Ric-style tuning a year or so ago. I like it. It still has the ring of a 12-string, but the sound of the octave strings is a little more muted compared to standard tuning. As I wrote above, I restrung it to standard. I'll keep it this way for now. Dan, Can you explain, for us not in the know, what is "Ric-style tuning"? | ||
DanSavage![]() |
Joined: June 2012 Posts: 2332 Location: Pueblo West, CO | arumako - 2020-03-10 5:45 AM Nice project, Dan. It looks like you left the bolt that holds the original battery case as is. Did you secure it at all? The black compensated saddle looks great too. Thanks for sharing. Thanks, Ken. No, I removed the battery case battery case bolt and filled the hole with a domed nylon plug which is similar to these. ![]() | ||
DanSavage![]() |
Joined: June 2012 Posts: 2332 Location: Pueblo West, CO | Tom The Piddler - 2020-03-10 6:48 AM Dan, Can you explain, for us not in the know, what is "Ric-style tuning"? Hi Tom, A picture is worth a thousand words. The first pic below depicts the standard 12-string tuning. Basically, it's 6 courses of 2 strings. The bottom four strings (EADG) are paired with strings that are tuned up an octave. The two upper strings (Be) are paired with strings of identical diameter and tuning. Rickenbacker reversed the tuning of the bottom four strings so the octave and normal strings are reversed.
Joined: March 2019 Posts: 26 Location: Cass County, Texas | Dan,
PS: the above pics are my first on OFC. Hope they meet OFC's requirements. | ||
DanSavage![]() |
Joined: June 2012 Posts: 2332 Location: Pueblo West, CO | Tom The Piddler - 2020-03-12 5:32 AM The tuner layout is probably why the "Ric-style tuning" Maybe. As I wrote, the two styles do sound different with the octave strings being less prominent in the ric-style tuning. | ||
