Adamas fingerboard extension
| rpguitar |
Joined: September 2007 Posts: 153 Location: New Jersey, USA | At the risk of tormenting myself by inviting opinions on this, I need to ask: Is the fingerboard extension on an Adamas I supposed to be attached absolutely flush with the top, or is a narrow gap normal? I can slide a 1.0mm pick between the fingerboard and the top on my pristine looking 1994 1587. It doesn't go all the way through; it stops about halfway. So the fingerboard is definitely attached to the top, just not at the edges. I've hunted down pics and seen examples of both. My inclination is to think it's normal to have a slight gap. What is the expert judgment on this? Thanks - | ||
| cliff |
Joined: March 2002 Posts: 14842 Location: NJ | The fingerboard should "float" . . . | ||
| brainslag |
Joined: April 2006 Posts: 1138 Location: CT | It's supposed to be that way. It allows more of the top to vibrate. | ||
| rpguitar |
Joined: September 2007 Posts: 153 Location: New Jersey, USA | << EXHALE >> Thanks guys! Totally appreciate the quick affirming replies. :) | ||
| cliff |
Joined: March 2002 Posts: 14842 Location: NJ | If it "bothers" you, a 1" sheetrock screw'll hold it down nicely . . . | ||
| TexasDoc |
Joined: December 2004 Posts: 1116 Location: Keller, TX | Originally posted by cliff: PLEASE DON'T!!!If it "bothers" you, a 1" sheetrock screw'll hold it down nicely . . . | ||
| rpguitar |
Joined: September 2007 Posts: 153 Location: New Jersey, USA | I was thinking about just pushing down on it really hard to make it "stick." (NOT) | ||
| Mark in Boise |
Joined: March 2005 Posts: 12762 Location: Boise, Idaho | The screw has been used, as has silicone sealer and other attempts to fix what isn't broken. It is designed to be free of the top as Cliff said the first time. If someone doesn't appreciate Cliff's sarcasm and screws the fretboard down, he or she probably deserves to have ridicule and scorn heaped on. | ||
| Todd G. |
Joined: September 2003 Posts: 815 Location: Colorado | Don't feel bad Roger. I asked the same question a few years back after I got my Adamas II. Guess I better remove that lag bolt from the 21st fret... | ||
| cruster |
Joined: May 2004 Posts: 2850 Location: Midland, MI | The extension on my AII is off the top on the bass side, but the treble side is in contact. I figure it warped. Maybe I should send it to cliffster for remediation. Or maybe Jeffro could come up with some medieval fix. :D | ||
| Beal |
Joined: January 2002 Posts: 14127 Location: 6 String Ranch | You only need a 1/2" screw, you don't want all that extra weight! | ||
| cholloway |
Joined: March 2005 Posts: 2793 Location: Atlanta, GA. | A case of "screwing up" the neck rather than screwing it down. | ||
| Thanksforallthefish |
| Joined: November 2004 Posts: 1374 | Callimachus had a 1537 with that modification I believe at one time.. Glenn | ||
| Tony Calman |
Joined: August 2003 Posts: 4619 Location: SoCal | Yep, wonderful job of ignorance and incompetence...guess the former owner thought it was peeling up. First came into the OFC from an eBay auction. Then, a couple of OFC'ers had it before I got it. Fortunately, taking out the screw...returned to the proper position. Repaired with a walnut plug...wonderful playing guitar. Not sure where it is now, I sent to to Stephen T-28 1/05. Then CWK2 took pity on me...I now have the finest 1537 that I have ever played. Course, before we have others saying their guitars are better, I played others. (They say ignorance is bliss) | ||
| Tony Calman |
Joined: August 2003 Posts: 4619 Location: SoCal | "Course, before we have others saying their guitars are better, I played others. (They say ignorance is bliss)" I meant to say I HADN'T played others :eek: | ||
