First timer to OFC, 1973, 1617-1 questions.
Buckie
Posted 2019-02-24 10:46 AM (#547137)
Subject: First timer to OFC, 1973, 1617-1 questions.
February 2019
Hello to All, recently purchased a 1973, 1617-1 Ovation. Very nice all original condition. Just like the one Jim Crose played, think that's what made me pull the trigger. Anyways, doing some cleaning and inspecting of guitar and now have some questions if any one can help. No.1, under the piezo bridge is 3 1/2 shims with the half being on the high E side. Is this normal, factory? No.2, under the truss rod plate on the headstock, there's a number in red ink that close to the serial number but doesn't match. The bowl number is 016152 and the headstock number is 16121. Factory error or normal occurrence? No.3, wanted to remove the electronics for testing and inspecting. The piezo pick-up wiring is soldered directly from the volume control box to the pick up. No way to remove unless unsoldering these delicate components, any ideas? Could I cut this wire and install 3.5mm plugs like the later models did? That's enough for now, thanks.
Posted 2019-02-24 1:34 PM (#547142 - in reply to #547137)
Subject: Re: First timer to OFC, 1973, 1617-1 questions.
guitars were shimmed to make them play the best they could there were no standard amount of shims it all depended on the neck angle
the number under the trc I have seen before I think that was some sort of internal inventory number but I am not sure
good luck with soldering those pickups
which preamp do you have?
if it is the stack knob I can provide modular preamp and pickup
good luck
Buckie
Posted 2019-02-24 4:26 PM (#547146 - in reply to #547137)
February 2019
The preamp is just volume. Knob looks like a fender amp knob. The small gray metal box it is attached to has a circuit board full of capacitors, resisters and what not. I think it is a very early one for Ovation. Battery box is a piece of u- shaped alumium that battery snaps into.
