New Member with another Viper solidbody
Chismes
Posted 2019-01-10 4:24 PM (#546491)
Subject: New Member with another Viper solidbody
January 2019
Hi all,
My name is Diego and I'm from Spain.
I just bought a white Ovation Viper, around here it is not very usual to see them and I have some doubts.
The first is about the type of wood of the body, this guitar weighs 4.5 kg (9.9lb), it could be a body of mahogany.
The guitar as I have seen is built between 1975-1980 according to the serial number E + 5 digits, someone has bounded more by series numbers the years?
The next is that he has a tuner replaced by another totally different one. The Schaller M6 nylon are adapted to this guitar, I mean the screw holes?
And finally I want to know if the brown hardcase of this Viper model is the same as the UK model ii.
Greetings, thank you, sorry for so many questions and hope someday help and not bother so much.
Chismes
Posted 2019-01-14 9:08 AM (#546538 - in reply to #546491)
Subject: RE: New Member with another Viper solidbody
January 2019
Chismes
Posted 2019-02-27 7:55 PM (#547168 - in reply to #546491)
Subject: Re: New Member with another Viper solidbody
January 2019
I self-answer
The tuners Schallers M6 Nylon (not mini version) are perfect to install.
The "only problem" is to change the Schaller logo for the Ovation logo, but I did it and it's quite simple.
Warm up very little water until it boils and submerge the black part of the tuner for 30 seconds, then hit the tuner part through the rope (the hole) and the sheet fell.
A greeting.
Posted 2019-02-27 8:04 PM (#547169 - in reply to #546491)
Hello Chismes.
I am not sure about the cases.
That being said... You are now a Member.
You should post your questions in one of the Main Forums.
There, you will find the wisdom that you seek.
Only a Few members can respond to the Welcome Center.
We are just the doormen...
Checking ID's and collecting the Cover Charge.
Welcome.
Chismes
Posted 2019-02-28 3:28 PM (#547174 - in reply to #546491)
January 2019
Thank you I will try to write a more complete article with photos.
