The Ovation Fan Club | ||
Random quote: "Got time to breathe, got time for music." --Briscoe Darling. |
Patch's Parlor Build...
DanSavage |
Joined: June 2012 Posts: 2303 Location: Lake Forest, CA | Since the Frankenvation is done, I'm moving onto my next project. Then, I'm going to remove the neck from this junked 1624 and convert it to a bolt-on neck. It'll get a sinker redwood top. I strongly encouraged Patch to go with torrefied spruce, but he strongly resisted because he's a real fan of sinker redwood. Since it's his guitar I let him have his way. I managed to find some honest-to-goodness hen's teeth. A NIB set of Schaller 541 gold tuners. These must be the last NIB set of these tuners in the world. And, the guitar will get an Optima preamp.
Edited by DanSavage 2017-09-16 12:20 PM | ||
DanSavage |
Joined: June 2012 Posts: 2303 Location: Lake Forest, CA | Back to the bowl. Parlor bowls are all but unobtainable. Since this one is currently in perfect, unused condition, I'm going to splash a mold from the outside before I use it for Patch's guitar. Because I'm sure everyone will find that process interesting, I'll document it here. Also, it's going to be a shiny bowl. Probably the only shiny bowl Parlor in the world. Edited by DanSavage 2017-09-16 12:25 PM | ||
Patch |
Joined: May 2006 Posts: 4221 Location: Steeler Nation, Hudson Valley Contingent | I can't thank Dan enough. When the market crash finally caught up with my, some would say out of control, guitar trading habit, I thought my custom build days were over. I wasn't all that bummed out as I had amassed a very satisfying collection of O's, but I did regret that I never got to move on to the next project I had in line at the time. I had discussed it with John Budny for years, but I wanted a Redwood parlor BAD! Now, not only do I get the parlor, but it will be a nylon string, shiny bowl, wide-neck, SINKER redwood one as well! I have nothing against torrified spruce at all, and I may let Dan scratch his itch to get some in my hands down the road. But for now, I'm looking forward to following this build almost as much as I am to playing the final result! Thanks again Dan! Edited by Patch 2017-09-16 7:39 PM | ||
moody, p.i. |
Joined: March 2002 Posts: 15652 Location: SoCal | Patch, if it means anything to you, I had Dan put a torrefied Adirondack spruce top and braces on my 1113. Best sounding Ovation O I've ever heard..... | ||
Jonmark Stone |
Joined: May 2008 Posts: 1553 Location: Indiana | Well... this'll be fun... | ||
DanSavage |
Joined: June 2012 Posts: 2303 Location: Lake Forest, CA | Removed the neck from the 1624 yesterday. I cleaned off the excess epoxy from the dovetail area. The square piece of metal between the fretboard extension and the dovetail is the truss rod anchor.
Taking the neck off this guitar was interesting. I knew it was an SMC bowl and there was a single bolt hole on the inside. I figured the neck was a dovetail neck, but I wasn't sure what was lurking inside the pocket. And, to top it all off, the molded-in neck block is quite thick, so I wasn't really enamored with trying to cut the neck off the bowl.
Edited by DanSavage 2017-09-17 5:27 PM | ||
Samuels |
Joined: January 2014 Posts: 78 Location: Boise, Idaho | I've got a 1997 parlor case with a mint interior to house this baby for you if you want it Patch, just cover the shipping and it's yours. | ||
DanSavage |
Joined: June 2012 Posts: 2303 Location: Lake Forest, CA | Hi Samuel, I can speak for Patch when I say he'll take it. I just PMed my mailing address to you. Please respond to the PM with the shipping costs and I'll paypal the money to you. Thanks again, Dan | ||
Patch |
Joined: May 2006 Posts: 4221 Location: Steeler Nation, Hudson Valley Contingent | Thanks Samuel, and Dan's right, I'm gonna need it. Dan, just let me know how to square up any costs. Edited by Patch 2017-09-18 7:38 AM | ||
DanSavage |
Joined: June 2012 Posts: 2303 Location: Lake Forest, CA | No worries, Patch. We'll work it out as time progresses. | ||
DanSavage |
Joined: June 2012 Posts: 2303 Location: Lake Forest, CA | It's been a while since my last update, hasn't it? Two months to be exact.
DanSavage |
Joined: June 2012 Posts: 2303 Location: Lake Forest, CA | When we last met I had temporarily glued the bowls to the inserts. Now it's time to start prepping them for molding. The parlor bowl has been primed and sanded. It's ready for waxing and the mold release layer. The deep bowl had a similar problem. The weave of the cloth needs to be filled to provide a smooth surface. The deep bowl has also been primed and is ready for the waxing and applying the mold release layer. The parlor bowl and deep bowls have had 3 layers of wax, then a layer of poly-vinyl alcohol (PVA) mold release. The basic idea is to prevent the molding epoxy from sticking to the molds. First the plug, in this case, the bowls are waxed. Then the PVA mold release is applied. The wax keeps the PVA from sticking to the plug. The PVA keeps the epoxy from eating through the wax and bonding to the plug. The PVA is an interesting compound. When dry, it forms a barrier that the epoxy can't penetrate, but can be dissolved with plain water. The surface of the PVA is a lot smoother than it looks in the photos below. Next job is to start laying up the molds.
DanSavage |
Joined: June 2012 Posts: 2303 Location: Lake Forest, CA | I might add that when I first started making molds I would paint the plug with a hard finish like epoxy paint, then polish the plugs to a mirror finish. I waxed the plugs, but didn't use PVA, so the epoxy would eat right through the wax and bond to the paint. I had a problem with the molds sticking to the plugs. The only way to get the plug out of the mold was to destroy the plug. When I started using PVA I discovered that the mirror finish on the plugs really didn't matter because the PVA was a new layer and that was the surface that was molded. Now I just prime the plugs, then sand it smooth with up to 600-grit, then wax and spray the PVA. It's a lot easier and a lot less time-consuming. Edited by DanSavage 2017-12-02 11:55 AM | ||
Patch |
Joined: May 2006 Posts: 4221 Location: Steeler Nation, Hudson Valley Contingent | This is so cool! | ||
Old Man Arthur |
Joined: September 2006 Posts: 10777 Location: Keepin' It Weird in Portland, OR | Oooo! I can't wait to see this. | ||
DanSavage |
Joined: June 2012 Posts: 2303 Location: Lake Forest, CA | The molding process has begun. Because I'm using a different brand of epoxy than I normally use I decided to mold my deep bowl first. This way, if there's any problems Patch's parlor bowl is still safe. (Made from unobtainium) I'm sure you've noticed the difference in color between the treble and bass bouts. I'd originally planned to add some yellow dry artist pigment to the surface coat so that I could see the difference between the white surface coat and the parting plate. But, because the PVA is tinted green, this is really unnecessary. Also the surface coat is really thick, so blending in the pigment was a royal pain in the butt. Next, a fillet of surface coat is laid into the joint of between the bowl and the parting plate. This is done for two reasons. First, it adds strength to this area of the mold. Second, the cloth doesn't really want to conform to a sharp angle, so this helps prevent voids from forming during the lay-up.
Final layer(s) of 17-oz. bias knitted cloth are on the plug. I'll let the epoxy cure for 24 hours, then I'll separate the plug and mold. | ||
tpa |
Joined: December 2004 Posts: 554 Location: Denmark | The PVA sounds interesting. How do you prepare it? Is it like this: http://www.sekisui-sc.com/wp-content/uploads/SelvolPVOH_Brochure_EN... | ||
DanSavage |
Joined: June 2012 Posts: 2303 Location: Lake Forest, CA | tpa - 2017-12-04 2:09 PM The PVA sounds interesting. How do you prepare it? Is it like this: http://www.sekisui-sc.com/wp-content/uploads/SelvolPVOH_Brochure_EN... I just pour PartAll Film #10 into my HVLP touch-up gun, then spray it on the waxed surface. (PartAll Paste Wax #2) Once a mold becomes seasoned (all the polymer chains are cross-linked) the PVA is unnecessary. The mold only needs a coat of wax between parts. Edited by DanSavage 2017-12-04 5:02 PM | ||
DanSavage |
Joined: June 2012 Posts: 2303 Location: Lake Forest, CA | And now, the moment of truth... Normally the next step would be to pour water in the gap to start dissolving the PVA. While looking into the gap between the mold and the parting plate I saw that the parting plate was loose from the mold, but that the bowl was still stuck to the inside of the mold. And, success! After some careful use of the wedges working my way around the bowl and pouring water into the gap I was able to get the bowl out of the mold with no damage to either one. (Woo hoo!) This is why I built the plug to be disassembled and with the hole in the insert. I've had too many plugs stuck inside the mold. I unscrewed the parting plate from the bowl/insert which gave me access to the bowl/insert. I had to pretty much destroy the MDC insert to separate it from the bowl. This would allow the bowl to flex enough for me to pour water down in the gap between the bowl and the mold. There are a couple of very minor flaws in the mold where some un-cured (poorly mixed?) surface coat were applied, but for the most part, I'm very happy with how it turned out and it can be used to lay up my own bowls. I'll use my Dremel and cutoff wheel to trim the excess mold flange in the next few days. Next job is to lay up a mold over Patch's parlor. Edited by DanSavage 2017-12-04 8:20 PM | ||
Love O Fair |
Joined: February 2016 Posts: 1769 Location: When?? | Cool. No, wait.. VERY cool. | ||
BanjoJ |
Joined: September 2012 Posts: 809 Location: Thredbo, NSW, Australia | Well done Dan! Will you brace the outside of the mould once it has cured? | ||
DarenSavage |
Joined: December 2016 Posts: 128 | This is high-end stuff, boys and girls. Great build thread, Dan. Edited by DarenSavage 2017-12-05 12:08 AM | ||
DanSavage |
Joined: June 2012 Posts: 2303 Location: Lake Forest, CA | BanjoJ - 2017-12-04 9:28 PM Well done Dan! Will you brace the outside of the mould once it has cured? Thanks Paul. No need for external bracing of the mold. It's quite rigid as it is. I may glue some legs to it so it sits level. | ||
DanSavage |
Joined: June 2012 Posts: 2303 Location: Lake Forest, CA | Love O Fair - 2017-12-04 8:09 PM Cool. No, wait.. VERY cool. Thanks, Al. | ||
DanSavage |
Joined: June 2012 Posts: 2303 Location: Lake Forest, CA | DarenSavage - 2017-12-04 9:47 PM This is high-end stuff, boys and girls. Great build thread, Dan. Thanks, Daren. We've been down this molding road a couple of times, haven't we? | ||
Jump to page : < 1 2 3 4 5 6 ... > Now viewing page 1 [25 messages per page] |
