Do you use your tone knob on solid body electrics?
| FlySig |
Joined: October 2005 Posts: 4081 Location: Utah | Does anybody here ever set the tone knob to anything other than max? I can't think of a time I have turned the tone down other than when wondering what it sounds like. EQ is done at the amp or PA, and from there I use the neck pickup for more mellow sounds and the bridge pickup for solos or a brasher rhythm sound. Besides, the tone controls don't seem to do more than turn the sound to mush. I'm considering rewiring at least one of my electrics so that each pickup has a volume control. It would be more useful than one master volume and a tone control. Unless there is some good reason not to that you know of. | ||
| Mr. Ovation |
Joined: December 2001 Posts: 7247 Location: The Great Pacific Northwest | That's interesting (and should get some interesting response) because others like myself tend to use the tone more than the Volume on my Ovation solid body guitars. I usually leave the volume wide open and setup the amp with the tone at about 3/4 open. Then for lead riffs I just open up the tone all the way, then back it off for rhythm again. When I run my Rockman gear, I do use the volume, but it is more to add distortion rather than volume due to the compressor in the Rockman. In this case I set the amp up for volume with the vol control on the guitar a little better than 1/2. Using the tone I can get cleaner sounds or slightly edgy, then punch the tone and vol controls for a big phat lead. By the way, if you are playing a Breadwinner, Deacon or Preacher Deluxe (the pre-amp'd guitars) the "normal" position for the tone is 50% and it either boosts the highs, or boosts the lows plus/minus from center. | ||
| alpep |
Joined: December 2001 Posts: 10583 Location: NJ | yes depending on which amp and how it is set, I often roll back the highs when it is way too piercing. I have a couple of amps with some really shrill speakers and I roll the tone back to mellow out the guitar sound. I also roll the vol back on occasion too so I can overdrive the amp and keep the vol at a manageable level | ||
| Beal |
Joined: January 2002 Posts: 14127 Location: 6 String Ranch | there's a tone control on guitars? | ||
| MWoody |
Joined: December 2003 Posts: 13996 Location: Upper Left USA | No. Until I read Miles' post... | ||
| brainslag |
Joined: April 2006 Posts: 1138 Location: CT | Depends on the guitar. On SGs or Les Pauls I rarely used the tone knob (which just bleeds off the highs to ground - and thus the mush). All my electrics now are active, and the tone knob is actually usable, and I can boost or cut highs without the mud. | ||
| ProfessorBB |
Joined: January 2006 Posts: 5881 Location: Colorado Rocky Mountains | I back the tone off slightly on the hollow-bodies and when using the bridge pick-ups on solid bodies, which is rarely because I prefer the cleaner and fuller sound of the neck pick-up. Also, I tend to back off the tone on humbuckers more than on single coils. I haven't messed with the VXT long enough to adjust the tone. So far, I've been having too much fun with the acoustic/electric knob and switching between the electric pick-ups. | ||
| GLW |
Joined: September 2006 Posts: 16 Location: Oxfordshire, UK | I use the tone on my Breadwinner because it actually DOES something on that guitar. On any other guitar I can't be bothered because all it is is a treble cut. Waste of time. | ||
| an4340 |
Joined: May 2003 Posts: 4389 Location: Capital District, NY, USA Minor Outlying Islands | For me and my tele, I crank up the tone to get maximum twang. I peel it off to get more mud and hollowness. A lot depends on your pups and your amp. | ||
| PEZ |
Joined: July 2003 Posts: 3111 Location: Nashville TN. | you mean those things that are always on 10??? | ||
| Tim in Tidewater |
Joined: December 2005 Posts: 1234 Location: Tidal Mudflats of Virginia | no, 11, everyone else only goes to 10, ours go to 11 | ||
| PEZ |
Joined: July 2003 Posts: 3111 Location: Nashville TN. | The volume knob on my Fender Champion 600 goes to 12 | ||
| Old Man Arthur |
Joined: September 2006 Posts: 10777 Location: Keepin' It Weird in Portland, OR | I used to mess with the tone(s) on my Pseudo-Strat trying to get an acoustic tone... Then I bought a Balladeer! :cool: [but I do like messing with the pick-up switch] | ||
| tragocaster |
Joined: July 2005 Posts: 354 Location: Flushing, MI | On Telecasters - yes. I constantly twiddle the tone knob. Volume too. On all other solid bodies, no. I leave the tones on 10, unless I'm playing "Sunshine of Your Love", when I'm on the front pickup with the tone knob off. That's why I play a Tele. For all of those little tonal variations that you can't get on any other electric guitar. | ||
| numbfingers |
Joined: January 2006 Posts: 1132 Location: NW Washington State | Originally posted by tragocaster: Have you tried a Viper? Not that it's a Tele, but it's fun to twiddle the pickup selector and volume knob!That's why I play a Tele. For all of those little tonal variations that you can't get on any other electric guitar. | ||
