piezo pickup
edhackem
Posted 2017-04-01 5:21 PM (#533505)
Subject: piezo pickup
November 2009
was changing the strings on my CS24PNBM and pulled the piezo out of it's slot. Apparently the metal contact strip became detached and now I can't find it. No amplification! Can one of the piezo's that I see on EBay from China do the same thing? They just plug into the equalizer it appears. Or maybe someone can recommend a direct fit. Thanks in advance--
Posted 2017-04-01 11:44 PM (#533511 - in reply to #533505)
Subject: Re: piezo pickup
Short answer.... Yes.
Longer answer... Your guitar has a CP-100 saddle, one piece pickup/saddle.
You can just get a aftermarket undersaddle piezo,
but you will also have to buy another saddle with a flat bottom.
I recommend a Tusq saddle.
I also recommend an Artec PP-607 or a PG-607 pickup. (an SF-607 will work too)
http://www.artecsound.com/acou/piezo.htm
These will plug into the Preamp.
You will probably have to remove the battery box to get to where the pickup plugs-in on an OP4BT preamp.
Cheaper, generic, Chinese undersaddle pickups with work also.
Posted 2017-04-02 12:19 AM (#533512 - in reply to #533505)
Oh... And you can contact Ovation to see about getting the correct part.
http://www.ovationguitars.com/contact
Call them during East Coast Business Hours.
edhackem
Posted 2017-04-02 8:25 AM (#533515 - in reply to #533511)
November 2009
found the missing contact strip and tried to repair the broken one to no avail. Just ordered another piezo off EBay what about grinding the high spots off the old saddle? Any chance that might work? Thanks for your input--
Posted 2017-04-02 7:45 PM (#533516 - in reply to #533505)
You could try to grind them down, that will also make you saddle much shorter.
You are in Pittsburgh... There should be a bunch of guitar shops there.
If you find one where they actually do repairs they should have a bunch of saddles, new and old.
Or... you can order saddles from eBay.
HERE
This one is bone and you would have to sand it to size
here
The difference being, some people like the tone of Bone, but others like the consistency plastic.
There will be a undersaddle pickup between the saddle and the top, with kinda nullifies that argument.
edhackem
Posted 2017-04-09 7:28 AM (#533598 - in reply to #533505)
November 2009
just a follow up to my post--spoke with an Ovation CS rep and they're sending me a new piezo and saddle N/C! Pretty good PR in my opinion
BCam
Posted 2017-04-09 9:31 AM (#533600 - in reply to #533505)
October 2014
That was the right way to go.
