Square Headstock Ovation
Scott Willis
Posted 2016-01-15 1:40 PM (#520360)
Subject: Square Headstock Ovation
January 2016
Greetings and salutations. I am posting this to inquire if any members have come across a mid to later 70's Ovation with a Square of "flat topped" headstock. It has what appears to be a genuine Ovation Made in the USA label inside, Model number is printed as being an 1132-4....serial number is 090856. The last two digits appear to be a different color than the first four. Ovation.com says this was produced in 1977 between the months of January and September of that year. I am at a loss to explain it other than a replacement neck. However, there are no indicators that it is not original...the patina matches overall and the inside sections of the body do not appear to have been tampered with. I have ben playing and repairing all sort of guitars since the early 70's and can reasonably assure that this is the original neck. Help guys...I am lost here...thanks
Posted 2016-01-15 1:50 PM (#520361 - in reply to #520360)
Subject: Re: Square Headstock Ovation
Hello Scott,
The original neck on those Ultras were foam and the fretboard was aluminum. Sounds like you have a well done replacement.
Posted 2016-01-15 1:50 PM (#520363 - in reply to #520360)
Photos would help.
Is it "flat" like a Martin headstock?
Or is it flat like someone cut the duckbill off of an Ovation headstock?
Scott Willis
Posted 2016-01-15 1:58 PM (#520364 - in reply to #520363)
January 2016
Thank you for the responses....the headstock is flat similar to a Martin....as soon as I figure out how to put up the photos I will do that....any direction here form experienced members is always welcome...thank you
Posted 2016-01-15 6:34 PM (#520369 - in reply to #520360)
Here you go...
http://ovationfanclub.com/megabbs/forums/thread-view.asp?tid=32848&...
Posted 2016-01-15 7:30 PM (#520371 - in reply to #520360)
And if you cannot get that to work...
Post photos of Photobucket, and put the link here so we can go there.
