The Ovation Fan Club | ||
Random quote: "Ovation Guitars really don't get the respect they deserve!" - Alex Pepiak |
Help on a '87 Kramer Ferrington KFB-1. non-O Project...sorry!
arumako |
Joined: October 2012 Posts: 1018 Location: Yokohama, Japan | Inspired by seesquares' "Another Matrix Rehab - Replace Your Divots, please!" I thought I'd start work on my easiest project sitting on the shelf. It happens to be a non-O project, so I went to the Kramer Forum, and posted a thread and pics, but there is very little interest/knowledge regarding these pre-Gibson acoustic electric Ferringtons; so I thought I'd start a thread here. After an hour or so of preliminary work, I had some general questions about the condition of the bass that I wanted to throw out there, so please bear with me. After finding the bass in the case with the bridge torn off, the previous owner tried to place the bridge on the soundboard with some wood screws! Ouch! The batteries explosion spattered acid inside of the soundboard, and began a serious corrosive process. I'll obviously need to make my own preamp case as parts are no longer available. The preamp is marked "Active Tone Booster" with an apparent part number of CE852. One of the Kramer Forum threads suggested that the preamp was made by TC Electronics. Fortunately, the preamp is still working! The preamp is configured a bit curiously...there is the usual quarter inch output soldered into the preamp PCB, but there is also an output jack assembly that is mounted onto the PCB. I'm wondering if the soldered quarter inch output was soldered in later??? Or...if it came stock this way with an output jack on the PCB and an output cable soldered in...what was the purpose of the output jack on the PCB??? Hmmm... Based on my often rather misguided observations, the biggest repair issue is going to be the bridge. I cleaned up the soundboard area around the bridge, and cleaned all the paint and glue off of the bottom of the bridge as well. The bottom of the bridge is absolutely flat and in good condition, but when I tried to dry fit it to the soundboard, I realized that the sound board was buldging up just a bit, and the bridge wan't flush to the soundboard...the edges are floating up just a half-millimeter or so...You can't really tell by the picture, but... So my question is, if I go through the usual bridge caul and clamping route, the bridge can be forced into position, and will certainly adhere fairly well; however, I wasn't sure how the acoustic electric piezzo (made by Shadow) would be affected. A half a millimeter of twist or buldge under the piezzo element could cause some serious issues...I think...but the Shadow piezzo looks a little different from what I'm used to with Ovations... Should I route under the bridge and make the soundboard surface completely flat so as to prioritize adhesion? Half a millimeter out of the soundboard where the strongest bond between the bridge and soundboard needs to be seems a bit risky?... Any thoughts would be greatly appreciated. I'm kinda hoping some of you might own one of these guitars or basses. Are they worth the trouble? or Should I just re-assemble this thing and get rid of it? Your input would be most appreciated! Thanks a bunch! | ||
seesquare |
Joined: November 2002 Posts: 3598 Location: Pacific Northwest Inland Empire | Well, dunno. Perhaps, secure the base, with whatever gluing & filling is required. Clamp the bridge back on, then route the saddle slot, so it's flat again, to accomodate the pickup baseplate. Tricky issue may be patching the paint chips, where the bridge busted loose. I think I'd just shoot a bunch of electronic contact cleaner into the preamp. Might neutralize the acid, somewhat. Couldn't hurt, I suppose. I would speculate the "extra" 1/4-inch port is for direct-out recording purposes, or routed to some other processor device, though you would probably expect there to be a switched jack, at the additional port. Have fun! | ||
numbfingers |
Joined: January 2006 Posts: 1110 Location: NW Washington State | If it was an alkaline battery that leaked, white vinegar will probably clean up the mess. You might want to rinse with water or a wet q-tip to get rid of the vinegar afterwards. | ||
arumako |
Joined: October 2012 Posts: 1018 Location: Yokohama, Japan | Thanks seesquare. Routing the saddle slot after assembly is a great idea! I'll definitely do that if there is any warping under the saddle after assembly. If things are working well after the re-assembly then painting is definitely going to be a challenge. Maybe a complete refinish? Naw, that would be way more work than I'd want to put into this thing. Thanks for the inspiration... And thanks for the cleaning tip numbfingers. I've got the whole preamp disassembled so the cleaning job will be pretty easy. I'll give the white vinegar idea a try. That should give this Kramer an interesting aroma! Thanks for commenting on a non-O project. I really appreciate the input! | ||
arumako |
Joined: October 2012 Posts: 1018 Location: Yokohama, Japan | Hi BFLG'ers. I hope you all don't mind my sharing my finished Kramer Ferrington. After following some great advice from OFCers, I was able to disassemble the original preamp, and clean the rusting with white vinegar. The integrity of the casing was sound, but I needed to coat it with rust-o-leum to ensure the rusting did not continue. Gave it about five coats of gloss black paint, and I was even able to find a new chrome 9V battery holder... As I expected, the most difficult part of this project was painting the bare wood around the bridge after reinstalling the bridge. Unfortunately, I rushed through the final finish phase and did a poor job of restoring the paint. However, I was able to get some nice consistent clamping for the soundboard and bridge. The Ferrington has a pretty soft laminate soundboard so the "bridge" warping concern was a non-issue, but the soundboard is just slightly bent out of shape. Fully appreciating the fretless configuration of this bass requires that I use flat wound bass strings...final setup and a test run... Well...she's not a stellar performer. I'll need to change the piezo and install a new bridge saddle for that; however, all things considered, she was definitely worth salvaging! Thanks for the comments and suggestions! Edited by arumako 2015-05-21 10:02 AM | ||
DanSavage |
Joined: June 2012 Posts: 2303 Location: Lake Forest, CA | I'm glad to see you brought this instrument back from the dead. Nice job. | ||
BanjoJ |
Joined: September 2012 Posts: 809 Location: Thredbo, NSW, Australia | Well done arumako! I hope you get a great sounding bass out of this. In any case, it's all good fun working on musical instruments. | ||
arumako |
Joined: October 2012 Posts: 1018 Location: Yokohama, Japan | Thanks for the kind comments DanSavage and BanjoJ. It really is great fun working on musical instruments. My son has taken a great interest in the bass as I progressed little by little on this project. Now Kramer is in his room and he's been practicing his glissando and funk slap techniques. It's amazing how quickly these youngsters pick-up this stuff and rewarding to see them take interest. Can't wait to get started on more projects this summer! Edited by arumako 2015-05-23 6:53 AM | ||
