RE: 12 str top, top separated from Welcome Center
Posted 2015-01-17 9:06 PM (#504825)
Subject: RE: 12 str top, top separated from Welcome Center
There is a posting on the OFC in the Welcome Center [12 string, top separated from bowl].
Mike W. posted sending it to Budny. Yes, this is probably the best recommendation BUT as Temp knows, the left bottom side of the top on my MM68 mando separated from the bowl.
Solution was to re-glue from inside (used paint cans on top until glue dried). Success even after about six years. If the whole top came off, then Budny. If a portion of the top, might be worth trying glue. Also, it would be important to check the braces.
