Strings for classical
Rolleijoe
Posted 2014-12-30 3:15 PM (#504287)
Subject: Strings for classical
October 2014
I'm looking for recommendations for classical strings. Searched the 2 online boys, and have it narrowed down to Hannabach, or T-I. I'd like a very traditional string. What are you classical players using? The local shop put EB on it, but I'm looking for a deeper/fuller sound.
Thanks guys,
Joe
iglupickin
Posted 2014-12-30 5:56 PM (#504296 - in reply to #504287)
Subject: Re: Strings for classical
If an Ovation or Adamus, the manual in my Classical indicates Adamas or Omega High Tension strings. Are they still available? Don't know. However when I bought my guitar the prior owner used Savarez 520J, a French made high tension nylon strings, and so far I'm happy with them. I'm on my second set and you can find them on-line.
Posted 2014-12-30 6:27 PM (#504297 - in reply to #504287)
Ditto on the Savarez 520J
Rolleijoe
Posted 2014-12-30 7:53 PM (#504300 - in reply to #504287)
October 2014
Thanks guys, I'll place an order, and give them a try. I know the Adamas steel strings are still available, but not certain on the nylon.
Posted 2014-12-30 10:14 PM (#504301 - in reply to #504287)
I think the manual calls for "hard tension" on my Country Artist 6773LX
I have been using D'Addario Pro-Arte EJ46
iglupickin
Posted 2014-12-31 7:27 AM (#504307 - in reply to #504287)
There was another brand of nylon strings (name escapes me?) that had a ball-end so you don't have to loop the strings on the bridge like conventional nylon strings BUT I had two of the strings pull the little knot thru the ball and not sure why? I won't use those again. FYI
Posted 2014-12-31 1:25 PM (#504322 - in reply to #504287)
I once had a solid-body nylon string guitar. (the brand escapes me)
Anyway, I tried some Martin Ball-end Nylon strings.
I didn't like 'em.
One string came undone at the ball end.
Another string broke near the ball end.
It isn't that hard to tie the strings.
(disclaimer: I do not currently own a nylon string guitar)
Rolleijoe
Posted 2014-12-31 2:12 PM (#504325 - in reply to #504322)
October 2014
arthurseery - 2014-12-31 1:25 PM
I didn't like 'em.
The shop put ball end EBs on it, I don't like them. This is my 1st classical, never tied one before.
iglupickin
Posted 2014-12-31 6:24 PM (#504331 - in reply to #504287)
That's the brand, they were Martin ball-end nylon strings! Not good and surprising since I bought them since I have used their steel acoustic strings for years with favorable results. However I recently went back to D'Addario steels on my Collectors shallow bowl and they sound great! Every once in a while I guess its good to try a different type of string. My ear changes from time to time and experimenting works!
Rolleijoe
Posted 2014-12-31 11:38 PM (#504339 - in reply to #504287)
October 2014
I used Martin Marquis for almost 30 years on my Gibson. SJ Deluxe, but changed a few years ago to the T-I Plectrums. What a difference. Had to play at a wedding a couple if years ago, and needed fresh strings, so went with the Martins in a pinch. Never again. Since they've moved all string production to Mexico, I feel the quality just isn't the same.
