How Do You..........?
Rolleijoe
Posted 2014-12-29 1:03 PM (#504223)
Subject: How Do You..........?
October 2014
The neck on the 1655 has a significant bow in it. I see no truss rod, how do you correct this?
Thanks,
Joe
Posted 2014-12-29 1:25 PM (#504224 - in reply to #504223)
Subject: Re: How Do You..........?
If it does not have a Truss Rod Cover on the headstock...
The Truss Rod is inside the bowl.
Be Careful.
jamesholl
Posted 2014-12-29 2:04 PM (#504226 - in reply to #504223)
June 2012
If you do have to adjust make sure you have the right size 'Hex Key. usually 5/16"
Do not use the 'nearest size' metric key as this could damage the truss rod adjustment aperture.
bburg
Posted 2014-12-29 2:37 PM (#504231 - in reply to #504223)
August 2009
and first loosen the strings and check out whether the neck bolts are tight. I got a 12-string as "unplayable" because the neck was loose and the truss rod was fastened to the end.....
Bernie
Rolleijoe
Posted 2014-12-30 3:10 PM (#504286 - in reply to #504223)
October 2014
Thanks guys, I think I'll leave this one to the pros. Don't want to mess it up.
