Tips on repairing a case crack?
Thunderbolt
Posted 2014-12-04 1:24 AM (#501473)
Subject: Tips on repairing a case crack?
April 2014
anyone ever repair a crack in there case? maybe you could pass on some tips or suggestions on how i could fix it? would appreciate the help! thank,s
(case crack.jpg)
Attachments case crack.jpg (116KB - 0 downloads)
Posted 2014-12-04 1:48 AM (#501474 - in reply to #501473)
Subject: Re: Tips on repairing a case crack?
Tan Duct Tape?
DetlefMichel
Posted 2014-12-04 4:40 AM (#501475 - in reply to #501474)
May 2011
I had an old brown case with several cracks and fixed them with 2-component epoxy.If you want to strengthen the crack a little you may carefully remove the case inlay and add some glas fibre on the inside together with the glue and then re-glue the case inlay over it. I did this before, too.The good thing is that the repair is almost invisible.
Lonnie
Posted 2014-12-04 7:15 AM (#501476 - in reply to #501473)
November 2013
DetlefMichel - Did the case inlay come out easily, without damaging it?
I have the same issue with a case, but was hesitant to remove the inlay, thinking I may do more harm than good.
Posted 2014-12-04 10:17 AM (#501478 - in reply to #501473)
I haven't ever tried, but it seems it would be similar to repairing a vinyl dash on a car. There are lots of repair kits available for that.
Posted 2014-12-04 1:04 PM (#501485 - in reply to #501473)
I've used Shoo-Goo with good success.
Mario
Posted 2014-12-04 1:16 PM (#501487 - in reply to #501473)
Subject: RE: Tips on repairing a case crack?
April 2003
Didn't someone here once use bondo to repair a case?
danomyte
Posted 2014-12-04 2:40 PM (#501494 - in reply to #501473)
January 2014
I have tried to remove the inlay once to harvest some latches for another case. That stuff is glued in there pretty damn good. I ended up tearing the shag-a-lichous carpet quite a bit and gave up before I completely destroyed the case. I've seen brown cases on Music Go Round for as cheap as $40 before so they aren't hard to find that's for sure. Some clear epoxy would hold that if you prepped it properly so the surface had some bite.
Jonmark Stone
Posted 2014-12-04 6:30 PM (#501503 - in reply to #501473)
You can hardly notice the repair...
(case.jpg)
Attachments case.jpg (383KB - 1 downloads)
