Lifted bridge
Mario
Posted 2014-06-05 1:03 AM (#487494)
Subject: Lifted bridge
April 2003
When a bridge is starting to lift and there is a gap big enough to fit a pick into, whats the best way to finish removing it to re-glue?
DanSavage
Posted 2014-06-05 5:19 PM (#487506 - in reply to #487494)
Subject: Re: Lifted bridge
June 2012
Can you post any photos?
Mario
Posted 2014-06-05 7:43 PM (#487510 - in reply to #487494)
Subject: RE: Lifted bridge
April 2003
heres a couple
(bridge2.jpg)
(bridge3.jpg)
Attachments bridge2.jpg (70KB - 0 downloads)
Attachments bridge3.jpg (89KB - 0 downloads)
Mario
Posted 2014-06-05 7:45 PM (#487511 - in reply to #487494)
April 2003
I put a pick in there to show the gap size.
dvd
Posted 2014-06-05 10:39 PM (#487514 - in reply to #487494)
Yikes, first thing I would do is Detune that sucker so the bridge doesn't go airborne. I'll let the BFLG crowd chime in from there. Gotta say though... I think that's the highest saddle I've ever seen on an O! No problems with break angle there!
Edited by dvd 2014-06-05 10:41 PM
Posted 2014-06-05 11:04 PM (#487515 - in reply to #487494)
Mario, take it to a good repair shop. It could probably be glued down for under $50. But definitely detune it in the meantime......
Posted 2014-06-05 11:08 PM (#487516 - in reply to #487494)
You playing slide, or something?!
Jus' kiddin'....
First thing I see, there's no screws to hold the bridge down. I don't think there's any harm in getting a couple of #2 x 3/4" machine screws installed to get it back to "premorbid" levels. Countersink the holes, so you can put some pearl dots over the screws.
You will want to reglue the bridge, with a couple of clamps, & the adhesive of your choice, before you screw it up.
Mario
Posted 2014-06-06 7:26 AM (#487521 - in reply to #487494)
April 2003
Thanks guys. This is a Folklore I thought was in good shape but when I got it I found the gap. I got the seller to take off a $100 for my trouble. The first thing I did was detune it. The funny thing is It is solidly on there, does not flex or more. There repair shop I took it to say it cant be glued as it sits because it has warped into place. It needs to come off, be planed down flat and then re-glued. I guess if I could find a deal on a replacement bridge i could heat up the old one remove it and glue in the new one. The saddle is pretty high but the action before detuning was actually pretty good. Let know if there are any bridges out there.
jay
Posted 2014-06-06 8:19 AM (#487524 - in reply to #487494)
January 2009
{{ Let know if there are any bridges out there.}}
A folklore is a great guitar. Let a luthier repair the original saddle. You want it done right. Surely if there is a bow in it, it can be taken out. Many years ago, I had a beautiful Elite LX and I heard this God awful noise, like it had fallen from the ceiling...the bridge had flown off...it looked terrible. A luthier in Dallas fixed it and there was no way you could tell it had ever exploded.
SOBeach
Posted 2014-06-06 8:52 AM (#487526 - in reply to #487494)
April 2010
Mario, I dunno if it's 'BFLG approved'  but, is the technique in this DIY vid of any help??
Acoustic bridge removal
http://www.youtube.com/watch?v=KcuxaFeDuH0
Although he didn't do it, he does suggest to first put on a low-tack tape (painter's tape) to protect the finish.  If it were mine... I'd follow that suggestion!!!
Mario
Posted 2014-06-06 10:10 AM (#487529 - in reply to #487494)
April 2003
Wow thanks for the video, thats tempting.
Posted 2014-06-06 2:31 PM (#487536 - in reply to #487494)
Mario, just contact the Mothershi .... oh, never mind
Mario
Posted 2014-06-06 3:09 PM (#487538 - in reply to #487494)
April 2003
Ouch!
DanSavage
Posted 2014-06-06 4:08 PM (#487539 - in reply to #487494)
June 2012
MG - 2014-06-06 5:26 AM
Ovation-style bridges can be ordered fairly cheaply from AllParts.com or via eBay...
http://www.allparts.com/GB-2866-0R0-Acoustic-Top-Loading-Bridge_p_1...
http://www.ebay.com/itm/Acoustic-Guitar-Wood-Bridge-Tailpiece-No-Pi...
An alternative to planing is to use a narrow scraper to scrape the glue off and smooth the top wood in preparation for gluing the new one down.
Edited by DanSavage 2014-06-06 4:21 PM
DanSavage
Posted 2014-06-06 4:18 PM (#487540 - in reply to #487526)
June 2012
SOBeach - 2014-06-06 6:52 AM
Acoustic bridge removal...
Yep. That's about the only way to do it.
Because the Ovation bridges are glued on with epoxy, you'll have to use a hot knife, like what's show in the video, or some other method that heats up the bridge to soften the glue.
A lot of luthier tape aluminum foil down to the top around the bridge to act like a heat shield, then apply the iron directly to the bridge to heat it and melt the glue underneath.
Epoxy will start to soften at ~170 degrees, so if you set the iron to wool or cotten, it should soften the glue without melting the finish.
DanSavage
Posted 2014-06-06 4:25 PM (#487541 - in reply to #487494)
June 2012
Mario,
The bridge probably came loose because the guitar was left in a hot car at some point in its life. This caused the glue to melt and the bridge to come loose.
The best glue to use for this repair would be hot hide glue (HHG) which does not come loose, even when left in a hot car.
I notice you're in Burbank. I have the set-up to glue stuff like this using HHG. When you're ready to glue the bridge, you're welcome to come on down to South Orange County and I'll help you glue it.
Posted 2014-06-06 4:58 PM (#487543 - in reply to #487494)
With no tension on the strings does the bridge sit flat onto the top? Or is there always a gap there? What has warped?
Mario
Posted 2014-06-06 5:15 PM (#487545 - in reply to #487494)
April 2003
Hey Dan thanks for the offer I may take you up on that. I will let you know. I actually work in Burbank live in Lancaster. Yes a big commute.
Yes with no tension the gap stays. The bridge itself is warped. The gap is only in the middle back and not on the sides at all. If you look from the top or bottom you can see a curve in the bridge. I will take a picture at that angle and post it.
Mario
Posted 2014-06-08 10:45 AM (#487580 - in reply to #487494)
April 2003
Here it is from the side. See how the back is up and the front and sides are down. The gap is only on the back middle. Anyway I guess Ill know when it comes off.
(bridge4.jpg)
Attachments bridge4.jpg (50KB - 0 downloads)
Posted 2014-06-08 6:21 PM (#487581 - in reply to #487494)
Yeah, Mario, along with a good chunk of the soundboard, maybe. I suggest a field trip to Trabuco Canyon. We're all bozos on the same bus, essentially, & it's an hour's drive. AND, it appears Dan knows what he's doing.
