Preacher Deluxe Wiring Diagram/Circuit Board
MIKEUP4TMI
Posted 2014-03-15 8:27 AM (#483142)
Subject: Preacher Deluxe Wiring Diagram/Circuit Board
March 2014
So... I found out my PD should have a circuit board in it and it doesn't. Anyone know of places that can make one or have them? If someone could post a picture of what it looks like under the pick guard, that'd be great too.
Posted 2014-03-15 3:51 PM (#483150 - in reply to #483142)
Subject: Re: Preacher Deluxe Wiring Diagram/Circuit Board
Good luck.. To my knowledge there is no one making anything similar that is a drop in. Finding one that is working these days is going to be tough as generally the only reason they aren't sitting in the guitar anymore is because it failed. Sometimes they were pulled for modifications like changing the pickups and eliminating the pre-amp... and those are the ones you are looking for if they were well kept. As with a lot of early 80's circuits, the capacitors are drying out. No one expected those parts to last this long. If it was stored well, kept in decent humidity for guitars... in other words used... then they last better than sitting on shelf on in someone's parts bin. Probably more than you needed to know.
When you post back, you will likely get upgraded to post in the general forums and that would be the place to ask. Someone may have a working one still kicking around.
