Old Applause neck...early Korean?
ksdaddy
Posted 2013-10-23 9:00 AM (#478206)
Subject: Old Applause neck...early Korean?
April 2003
Picked this up on ebay just for display in the Applause room. It appears to be brand new, never installed (tuner mounting holes never drilled, etc). I'm not sure what to think of it. It is a BOLT on like the Moosup Applauses but it is clearly all wood with an adjustable truss rod. The female threads are inside a piece of round stock that was inserted from the end cap area. The portion of the neck that would insert into the neck block is different than a Moosup Applause as well.
Any Korean Applause I've ever owned or examined had GLUED in necks. Now maybe the early ones were bolt on... I do not know. Were they ever bolt on?
So this could be a USA attempt to modify the Applause line, it could be a Korean test run, it could be a replacement neck for an early Korean Applause (assuming they were EVER bolt on)... anyone have any ideas? At first glance it looks like any Korean AA-31 neck....except for the bolt holes.
Edited by ksdaddy 2013-10-23 9:02 AM
sycamore
Posted 2013-10-25 6:54 PM (#478309 - in reply to #478206)
Subject: Re: Old Applause neck...early Korean?
March 2007
looks exactly like mine which has Made in USA on the label. Cant see if bolted or glued but the head and fretboard look exactly like mine. None of the visible parts of neck on mine look like wood though.
sycamore
Posted 2013-10-25 7:04 PM (#478310 - in reply to #478206)
Subject: RE: Old Applause neck...early Korean?
March 2007
one bad photo here
(IMG-20131026-00396.jpg)
Attachments IMG-20131026-00396.jpg (61KB - 1 downloads)
sycamore
Posted 2013-11-04 6:25 AM (#479610 - in reply to #478206)
March 2007
The heel on mine looks like a seperate piece and could be wood.
ksdaddy
Posted 2013-11-04 8:28 AM (#479612 - in reply to #478206)
April 2003
Yours is an Applause with a wooden neck and it's stamped made in USA? I'd like to see more pics if possible.
Posted 2013-11-05 4:38 PM (#479665 - in reply to #478206)
that's a Korean neck from Saehan
ksdaddy
Posted 2013-11-05 4:43 PM (#479666 - in reply to #478206)
April 2003
So were some of the Koreans bolt on?
sycamore
Posted 2013-11-06 6:56 AM (#479688 - in reply to #479612)
March 2007
Yes its a really unusual and special one so I might let go for a grand if you really want it!!
Seriously though, I've never seen one exactly like in, in real life on online. The blue paper label said 'Made in USA' but its been partly torn off though I may have an older photo of it. I'll try and take better pictures on a real camera.
I've always assumed that the neck is synthetic but maybe they'e just done a really good job finishing a piece of wood to look like plastic??? If I look at the neck block inside the body I don't see any bolts so always assumed it's glued in.
Edited by sycamore 2013-11-06 7:01 AM
sycamore
Posted 2013-11-06 7:06 AM (#479689 - in reply to #478206)
March 2007
ist very like this except the front of the headstock is not black, it is the same colour as the back.
http://www.ovationtribute.com/Acoustic%20Series/Applause/AA-31%20Ap...
sycamore
Posted 2013-11-09 6:40 AM (#479813 - in reply to #478206)
March 2007
OK ill try attaching photos now
(AA31 rear view.jpg)
(AA31 heel.jpg)
(AA31 front view.jpg)
(AA31 headstock front.jpg)
(AA31 headstock back.JPG)
Attachments AA31 rear view.jpg (98KB - 1 downloads)
Attachments AA31 heel.jpg (91KB - 0 downloads)
Attachments AA31 front view.jpg (86KB - 1 downloads)
Attachments AA31 headstock front.jpg (94KB - 1 downloads)
Attachments AA31 headstock back.JPG (91KB - 0 downloads)
ksdaddy
Posted 2013-11-09 10:08 AM (#479817 - in reply to #478206)
April 2003
Yep, definitely a typical AA31.
sycamore
Posted 2013-11-11 4:28 AM (#479850 - in reply to #478206)
March 2007
So is my neck wood or synthetic?
ksdaddy
Posted 2013-11-11 4:45 AM (#479851 - in reply to #478206)
April 2003
All wood. No loonium or spray foam.
sycamore
Posted 2013-11-11 4:56 AM (#479852 - in reply to #478206)
March 2007
Any idea what kind?
