"Downgrade" to an OP-30 in my Painted-T
Posted 2013-10-10 2:44 AM (#477862)
Subject: "Downgrade" to an OP-30 in my Painted-T
In other threads I have mentioned that I prefer the OP-30 over the OP-Pro.
The OP-30 has higher output than the OP-Pro.
That may not matter on stage, but it does if you are using a battery-powered amp.
Anyway, I was lucky enough to score a Used OP-30 & Can... so I put it in the Painted-T.
I have other O's with the OP-30... My Shallow T and the Red Flamer.
I like the versatility of the OP-30 with the Mid-Shift, Pre-Shape, and EQ in/out buttons.
I also like that the OP-30 mutes when you engage the tuna.
So this will be good for playing on the Street.
Plus the Painted-T is my foul-weather beater...
It's that time of year again the the Great Northwest.
Just wanted to Share that.
Posted 2013-10-10 10:45 AM (#477868 - in reply to #477862)
Subject: Re: "Downgrade" to an OP-30 in my Painted-T
You should have painted the rim of the can red before you installed it.
Posted 2013-10-10 5:49 PM (#477877 - in reply to #477862)
I took the Painted-T out today and played for a bit.
It sounds much better with the OP-30.
I am pleased.
MIB... That is a Good Idea!
Posted 2013-10-10 7:24 PM (#477879 - in reply to #477862)
My favorite is the OP50 which is hard to find, then the OP30.
