Ovation case latches
gmaslin
Posted 2013-10-04 5:34 AM (#477677)
Subject: Ovation case latches
September 2013
Is there a way to repair these without popping out the rivets and doing a full when only the flip latch part is missing? Is there a way to replace the lock or the key if the key is missing?
gmaslin
Posted 2013-10-04 11:07 AM (#477682 - in reply to #477677)
Subject: Re: Ovation case latches
September 2013
edit...and doing a full replacement of the latch...
dvd
Posted 2013-10-04 11:40 AM (#477687 - in reply to #477677)
by the flip part of the latch, do you mean the lever or the "loop" that clips over the other side? I have a case where somebody has rigged up a coat hanger wire or something similar to replace the loop bit. I can snap a pic if that helps.
I think the key is generic and I'm sure the mothership or somebody here could send a replacement.
gmaslin
Posted 2013-10-04 1:40 PM (#477691 - in reply to #477677)
September 2013
dvd
Yes, I meant the loop which is somehow missing from a case I saw so that it wouldn't close, thanks for the reply. A flexing metal loop like from a coat hanger would probably do the job but it sure would be ugly.
Puppetman
Posted 2013-10-04 9:42 PM (#477712 - in reply to #477677)
August 2011
If it's a tan case, I have the latch part ... don't know if the same latches were used on the other Ovation cases.
Edited by Puppetman 2013-10-04 9:51 PM
gmaslin
Posted 2013-10-05 8:20 AM (#477718 - in reply to #477677)
September 2013
Puppetman
Awesome! Does anyone have any tips on how it should be mounted on the lock or if there is a difference in the latches used on different cases?
