Ovation Elite Preamp hiss
SteveO
Posted 2008-02-15 6:12 PM (#54469)
Subject: Ovation Elite Preamp hiss
February 2008
Howdy,
I just purchased a 1993 Collector's Edition guitar with a three band equalizer, no tuner, single volume control. I am really surprised at the level of background hiss I get out of the on board preamp. I was led to believe that the electronics would be extremely quiet. The level of hiss that I get would prevent me from recording with this guitar which is a big disappointment. I wonder if there might be something wrong with the preamp? I also get some strange mixing products on certain notes that produce some higher frequency buzzings.... hard to explain really, but doesn't sound right. I'm just playing clean through a known good amplifier.
Any tips would be appreciated.
The upside is that the guitar really sounds great unplugged !
Steve
Ovation 1111
Martin D35
and now: 1993 Ovation Collectors
Posted 2008-02-15 6:31 PM (#54470 - in reply to #54469)
Subject: Re: Ovation Elite Preamp hiss
Since you've eliminated the amp, it could be a piezo thing or the pre-amp. After checking for lose wires, I'd bring it to a professional.
PEZ
Posted 2008-02-15 6:46 PM (#54471 - in reply to #54469)
July 2003
You definately have a repair issue.
It should be quiet.
You may not want to use the pick up to record with.
A condenser mic is the way to go to record.
scott lamperd
Posted 2008-02-15 7:26 PM (#54472 - in reply to #54469)
I have had several Ovations of that vintage and had very little noise with the preamps. You probably have an electronics problem. A trip back to the mother ship might be in order. I suppose you have checked the obvious...
Low battery voltage
bad cables
internal plug from the pickup to the preamp
mis-match of impedance to the recording board
Good luck Scott
scott lamperd
Posted 2008-02-15 7:27 PM (#54473 - in reply to #54469)
Low battery voltage
bad cables
Good luck Scott
SteveO
Posted 2008-02-15 10:11 PM (#54474 - in reply to #54469)
February 2008
Well I'll be.... low battery was it.
Just because the light comes on when you press the battery check button doesn't mean the battery is good.
New battery and all is sweet. Just an amazing musical instrument.
Thanks !
Steve
Posted 2008-02-15 10:17 PM (#54475 - in reply to #54469)
A cold solder joint or a broken shield can cause some hiss.
Also, way back when, I use to have to invert my amp wall plug at times. Is that still an issue nowadays with the polarized jacks? :confused:
BruDeV
Posted 2008-02-15 10:49 PM (#54476 - in reply to #54469)
Posted 2008-02-15 11:05 PM (#54477 - in reply to #54469)
Oops, just in time to be to late...
I'm glad ya fixed her!
