OP Pro experts - what's the 'OUT' for?
muzza
Posted 2008-02-21 8:30 PM (#53447)
Subject: OP Pro experts - what's the 'OUT' for?
August 2005
Any idea what this empty jack is for?
Posted 2008-02-21 8:42 PM (#53448 - in reply to #53447)
Subject: Re: OP Pro experts - what's the 'OUT' for?
Now what are you doin' pokin around the inside of your guitar? Is it a 1/4" jack? I would almost think that since the xlr and 1/4 out are on the same "board" that's fed by the other wire harness, this may be a 1/4 out that you could plug into an amp sans the xlr output. Just a guess though.
Posted 2008-02-21 8:43 PM (#53449 - in reply to #53447)
That's the extra hole. Used for the alternate IN position. Often doesn't work properly.
Posted 2008-02-21 8:46 PM (#53450 - in reply to #53447)
I thought it was for 1/4" as well.
Posted 2008-02-21 8:58 PM (#53451 - in reply to #53447)
I think it works just fine. Sometimes you just have to force it a little. Dave
colt357
Posted 2008-02-22 1:28 AM (#53452 - in reply to #53447)
muzza
Posted 2008-02-22 4:15 AM (#53453 - in reply to #53447)
August 2005
Is it a 1/4" jack?
Nope, it's a 1/8" jack.
So, nobody REALLY knows what it is then? :confused:
Posted 2008-02-22 5:00 AM (#53454 - in reply to #53447)
There are 2 versions of the Op-Pro, one with XLR/jack outputs and one jack only. The XLR/Jack version uses the multi-pin socket on the preamp can, the jack only uses the 1/8th" phone-socket. At least that the case with my 1773-LX.
Posted 2008-02-22 6:44 AM (#53455 - in reply to #53447)
Paul's got it. If you have an OP-Pro with 1/4" only, you'll find the lead from that jack plugged into the 1/8" jack on the OP.
PEZ
Posted 2008-02-24 1:36 AM (#53456 - in reply to #53447)
July 2003
I was about to look at mine......
I forgot that its at the Mothership having the xlr added
PEZ
Posted 2008-02-24 1:38 AM (#53457 - in reply to #53447)
July 2003
op50 has one too
