Balladeer 4861 Action Adjustment
| LeonardDB |
Joined: February 2008 Posts: 14 Location: Rhode Island | From the Ovation Manual: 1. Remove the saddle carefully. This is a delicate operation particularly if you have an acoustic-electric model. Be certain not to pull or force the wiring beneath the saddle. 3. For lower than standard action, remove a shim beneath the saddle. Removing one shim will lower the action by 1/64" at the 12th fret. Do I remove the white plastic piece or remove as a whole unit the metal seat and the white plastic piece together? I don't want to hose the pick up wiring. | ||
| Weaser P |
Joined: October 2005 Posts: 5332 Location: Bluffton, SC | Can't specifically answer the question but IMHO this guitar sounds like it could use a professional setup. Sure there are things you can do but I would tread lightly on some of it if you're not experienced. That's just one opinion though - others may disagree. | ||
| LeonardDB |
Joined: February 2008 Posts: 14 Location: Rhode Island | Adjusting Guitars is not rocket science. You just have to follow the correct order of what to adjust. | ||
| Capo Guy |
Joined: December 2004 Posts: 4394 Location: East Tennessee | Originally posted by LeonardDB: Remove the whole unit. If it appears to be stuck you can reach inside the guitar and GENTLY push up on the wire. I know the first time I did it I was a little skittish.From the Ovation Manual: Do I remove the white plastic piece or remove as a whole unit the metal seat and the white plastic piece together? I don't want to hose the pick up wiring. | ||
| LeonardDB |
Joined: February 2008 Posts: 14 Location: Rhode Island | Thanks Capo Guy. The manual is not really clear on this procedure. Much appreciated. | ||
| LeonardDB |
Joined: February 2008 Posts: 14 Location: Rhode Island | Capo Guy, once you pull the whole unit out is there any particular way of disassembling the unit to get at the shims? I do not want to do anything to disturb my pick up. | ||
| G8r |
Joined: November 2006 Posts: 3969 | The shims simply rest under the peizo/saddle assembly - all you'll need to do is lift that assembly out of it's slot in the bridge and then remove one (or more) of the shims. It's very easy, just don't break the wires. I always find it easier to push the pickup assembly up from inside the guitar. | ||
| 2ifbyC |
| Joined: December 2006 Posts: 6268 Location: Florida Central Gulf Coast | - Loosen or remove strings for inside access and saddle/pup removal - Remove saddle - Reach inside and gently push up the pup lead as close to the soldered connection as possible - From the top gently release and lift out the pup assembly comprising of the copper 'tray' and piezo 'wafer'. - remove one shim - reassemble and setup/test - repeat as necessary It's not difficult. Just go slow and be gentle (That's what she said!). :D | ||
| Mark in Boise |
Joined: March 2005 Posts: 12762 Location: Boise, Idaho | I had the same problem the first time I tried it. The white plastic thingy fell out and I didn't remember where it came from. The shims are usually brown and look like wafer board. They go in the bottom. Once you do one, the rest are easy. | ||
| dvd |
Joined: December 2003 Posts: 1889 Location: Central Massachusetts | Mark, clean out your PM box! | ||
| Mark in Boise |
Joined: March 2005 Posts: 12762 Location: Boise, Idaho | Done. Sorry, I've been consulting several experts lately. | ||
| 2ifbyC |
| Joined: December 2006 Posts: 6268 Location: Florida Central Gulf Coast | Originally posted by Mark in Boise: I took the liberty to correct your post... ;)Done. Sorry, I've been consulting -FOR- several experts lately. | ||
