DS768 Longneck samples
Posted 2013-03-06 2:50 PM (#468090)
Subject: DS768 Longneck samples
Playing with the Longneck. It's unplugged with a mic on it. It's been hard putting this thing down since I got it.
Longneck DS678
dvd
Posted 2013-03-06 9:15 PM (#468111 - in reply to #468090)
Subject: Re: DS768 Longneck samples
Awesome, Damon. That longneck is full of mojo..
Posted 2013-03-06 9:34 PM (#468112 - in reply to #468090)
That explains why I lost my mojo.
I left it all in my old longneck.
dvd
Posted 2013-03-06 10:27 PM (#468120 - in reply to #468090)
Stephen, I hope you charged extra for that! Does that add to the shipping cost?
Posted 2013-03-07 9:16 AM (#468131 - in reply to #468090)
Glad you're happy with it, Damon. You did have me worried for a bit.
Posted 2013-03-07 10:52 AM (#468134 - in reply to #468090)
dvd,
I think Waskel sucked out most of the mojo I left. Damon is probably using Waskel's mojo and generating a lot on his own.
Posted 2013-03-07 5:36 PM (#468154 - in reply to #468090)
No, but I did clean the gummy bears out of it...
Posted 2013-03-07 5:58 PM (#468159 - in reply to #468131)
Waskel@Work - 2013-03-07 7:16 AM Glad you're happy with it, Damon. You did have me worried for a bit.
There's only one way this thing would be leaving here.... that's if a 2080D was on it's way to replace it!
Posted 2013-03-08 10:38 AM (#468182 - in reply to #468090)
Now THAT statement sounds very familiar Damon.
TAFKAR
Posted 2013-03-09 1:53 AM (#468204 - in reply to #468090)
Very nice. Wow, didn't know the strings would cope with a B tuning. I never tried that when I babysat AJ's longneck.
CanterburyStrings
Posted 2013-03-09 5:39 PM (#468214 - in reply to #468090)
March 2008
Damon, what guage strings are you using? I have 14's on mine and want to go heavier. (There's is a set of 15's sitting here that I will put on soon.)
Posted 2013-03-10 10:23 PM (#468234 - in reply to #468090)
Alison, I have EJ18s on it, the same as you probably?
I should note that if you intend to do a lot of back and forth tunings, especially something as drastic as D to B, buy some extra 14s. The high E breaks after a few up-downs on the tuning.
Also it should be noted that when I received this guitar, it had full on baritone strings on it and had started to belly quite severely. The first week I had it, I took the strings off, had a damp cloth inside an open bag sitting inside the bowl, and sat it right over my humidifier to see if it would get back close to normal, which it has for the most part. I think if you're tuning to B, sure, go for heavier strings, bt be careful with what you put on with the D tuning. I on't thing 15s would be too much different if you're building your own set. Just be careful on the lower strings.
Slightly off topic - After getting the '84c from Stephen high strung nashville style, I've been playing around some more with tunings. Right now I have my Anniversary Legend high strung B to B with the last string tuned down instead of up like the rest. It took me a while to figure out what diameters to use, but in the end I ended up going with:
B-39, E-29, A-18, D-14, F#12, B16
Posted 2013-03-11 3:34 PM (#468256 - in reply to #468234)
damon67 - 2013-03-10 8:23 PM
A victim of bad advice, I swear it. Glad it recovered!
