Worn saddles on the Elite
dwg preacher
Posted 2013-01-01 11:28 AM (#463711)
Subject: Worn saddles on the Elite
October 2012
Restrung the Elite this morning, with D'addario EXP16s. The previous owner had extra-lights on it, and I thought 12-53 gauge would probably beef up the sound a little...
What I noticed, after removing the strings is the saddles have grooves worn in them that seem to pull the strings slightly off-straight. I pulled them out of the grooves so they pull straight from bridge to nut, but I was wondering, is this gonna be an issue down the road? Should I be planning to have the saddle replaced sooner than later? Is it something I could consider doing myself? What has been your experience?
Also, thanks to the previous owner, I found the extra shim in the case, so I added it under the saddle, so (and my miserable technique is well documented, heehee) the action is a bit higher and the strings don't slap the upper frets when I'm finger-picking.
Posted 2013-01-06 3:59 PM (#463896 - in reply to #463711)
Subject: Re: Worn saddles on the Elite
I have lightly filed the grooves in saddles without any problems, and have filed new notches. The pointy top of the plastic saddle isn't strong enough to resist deformation. Why the strings get off center I don't know but mine have done it too.
Posted 2013-01-06 4:20 PM (#463902 - in reply to #463711)
There are some "porcelin" repair products and possibly some ok epoxies if you had to build up a saddle.
Nordicnorm
Posted 2013-01-24 8:52 PM (#464524 - in reply to #463711)
May 2010
The plastic saddle "insert" is replacable. It is held in place by the silicone in which the pick-ups are imbedded. It is easily removed without damaging anything else.You should be able to get a replacement. I got one from the Canadian arm of the MS, located in Toronto, Ont.
I would try building the top edge up with supr glue, then filing the side that faces the soundhole so you get a clean edge to avoid string buzz or intonation problems.
When you re-string, it is important to check the string spacing/alignment over tha saddle before you tighten the strings down. They will over time create grooves in the saddle, and if the grooves are off-set, it can be a bit of a struggle to set it right.
dwg preacher
Posted 2013-01-25 8:41 AM (#464533 - in reply to #463711)
October 2012
Thanks, everyone, for the information. I'll be restringing again in a week or so, and I'll take another look at that time. I was looking at them last night, and they look straight; like the strings haven't slipped down into the grooves again yet. Wondering if that's a sign of neglect? Old strings stayed on for years and years? Thanks especially, Norm. I'll plan to look into a new replacement saddle in the future.
