Ovation Case Repair
Posted 2008-03-09 3:01 AM (#50752)
Subject: Ovation Case Repair
Hello All,
Does anyone have any ideas for fixing the cracks that seem to appear on the older (tan) Ovation cases? I'm not talking big gouges or anything but those little hairline cracks that are probably from age and temperature change. I have seen cases where parts of the plastic outer shell are breaking into bits, and I assume they all started as one of these hairlines.
A guitar I just shipped developed one, and other than that, it's in pristine condition. We're looking for something to seal the crack. Maybe an epoxy or resin, but also don't want something that will just cause more problems later.
Thanks
Posted 2008-03-09 3:32 AM (#50753 - in reply to #50752)
Subject: Re: Ovation Case Repair
The case in case here:
Thanx Miles!
Posted 2008-03-09 3:46 AM (#50754 - in reply to #50752)
Yes, 2ifbyC follow these instructions and do not deviate.
1. Place UKII in cracked case, put cracked case inside of box with packing material
2. Ship to:
500 108th Ave NE
Suite 800
Bellevue, WA 98004
You won't have to worry about the crack ever again, I promise you.
Posted 2008-03-09 4:26 AM (#50755 - in reply to #50752)
...picky, picky, picky!
Actually, I asked Miles if it was cracked prior to shipment. He was concerned and very gracious in posting here prior to going through the insurance BS. I would much rather have the OFC hive mind come up with a solution rather than putting him through the crap of a claim. Our main concern is preventing further damage.
BTW, the UK II (3 pup) is totally SWEET! It's all that Miles said it was plus. If he ever has another git I'm interested in, consider it SOLD without any reservations!
noah
Posted 2008-03-09 5:47 AM (#50756 - in reply to #50752)
Polyurethane Hot Melt Adhesive looks promising. I was thinking about trying the MP75 (multi-purpose formula) to close up a crack in an old black case.
Fred showed me a Hot Melt Silicon which would probably be better.
As these cases age, the outer skin gets brittle.
Minor impacts and/or flexing result in cracks.
There would have to be shipping-box damage to go along with that case crack? I would still file a shipping damage claim.
Posted 2008-03-09 7:29 AM (#50757 - in reply to #50752)
You might try one of your local "leather medic" or other automotive interior repair people. They are all mobile and you should be able to find one (maybe under a different name) in the yellow pages. I believe they do interior plastic trim on cars, so this should be right up their alley.
bauerhillboy
Posted 2008-03-09 10:26 AM (#50758 - in reply to #50752)
Waddyah mean, old cases? Every 9158 I've had has done that. And my cases don't get a lot of wear and tear.
John <>{
Northcountry
Posted 2008-03-09 10:40 AM (#50759 - in reply to #50752)
Personally I do not think these can ever be totally fixed. They are like the problems the dashboards in cars of the 70's had. Enough sun and heat and they would crack open every time with no good fix. The case material is harder but I will bet it has the same inherent problems with longevity those other early plastics did.
To stabilize that crack I'd suggest you find a good tape that will seal the crack on the front to keep anything from seeping to the outside during repair. Flip it over and remove the case interior material to get at it from the back. I would then suggest a piece of fiberglass cloth and some good epoxy resin. Make a barrier so the resin does not travel to far from the crack approx. 3" wide submerse the woven fabric into the resin and let it set up. reinsert case material and remove tape from outside. For color match repairs experiment with the many mixable resins and color choices available.
I use a complany called Smooth On quite often for the custom scale model parts I build at work......good strong stuff! or use straight up uncolored epoxy and experiment with some permenent markers to find a color match as close as you can get on the front after this is done.... Or buy a bunch of road case band stickers and go nuts!
Randy
Posted 2008-03-09 11:00 AM (#50760 - in reply to #50752)
or replace them all with carbon fiber cases. call al. :cool:
Posted 2008-03-09 4:31 PM (#50761 - in reply to #50752)
One MISTAKE that I know a lot of people have done, including myself before I learned, that Armor ALL should NEVER be used on things like this or dashboards, unless you intended to keep treating it every few months from that point forward.
Posted 2008-03-10 2:18 AM (#50762 - in reply to #50752)
First of all, thanx to Miles for stepping up and posting (honestly, I asked if he would due to his stellar rep here).
Now in order of postings:
Damon67 , nice try!
noah , great link. I just don't think it would be the best in this 'case'. I will have to check out that system for my other projects though.
Trader Jim , that's the route I'll try first! If I 'go there' and it works out, I'll send ya a coconut shell pick when I perfect my 'nut' technique.
bauerhillboy , I have seven simular cases and this was the first one with this condition.
Northcountry , too intrusive! But thanx...
lanaki , not after checking out the other thread!
Mr. Ovation (Miles), most folk do not realize the problems that Armor ALL and WD40 can and has caused! Short cuts usually mean major issues in the long run (been there, done that)!
Thanx to all for your inputs!
MarkM
Posted 2008-03-10 2:33 AM (#50763 - in reply to #50752)
September 2005
.... ideas for fixing the cracks that seem to appear on the older (tan) Ovation cases? I'm not talking big gouges or anything but those little hairline cracks that are probably from age and temperature change.... We're looking for something to seal the crack....
First things first. 'Stop Drill' the ends of the crack. The end of the crack is a 'stress riser'. Drill a small hole that provides a smooth surface beyond the original end of the crack.
Now use an adhesive over the crack area. Epoxies with glass cloth can bond, but most likely a solvent style adhesive for ABS will work on these cases. Please correct me if I'm wrong.
M^2
Posted 2008-03-10 2:53 AM (#50764 - in reply to #50752)
I already did the ol' windshield/plexiglas relief drill trick. Didn't take much (1/16") to help.
I won't use any type of epoxies due to the activator. I just can't take the chance with the internal foam!
Posted 2008-03-10 9:26 PM (#50765 - in reply to #50752)
This is what I did and it worked great. Of course, it looks like a patch, but it's not that bad and adds character. I believe it was Paul Temp who told me about the fiberglassing.
http://www.ovationfanclub.com/cgi-bin/ubb/cgi/ultimatebb.cgi?ubb=ge...
You can also tuck in weather stripping near the valence to keep out water.
Posted 2008-03-10 9:29 PM (#50766 - in reply to #50752)
And the amour all didn't cause any problems after 3 years. Though I only used it once.
Posted 2008-03-10 9:30 PM (#50767 - in reply to #50752)
I've used Automotive fibreglass bodge kits. They produce a very solid repair which can be made to look OK if you spend a little time. There's a Tamiya tan acrylic spray paint available from hobby shops which is a reasonable match for the case colour.
Posted 2008-03-10 9:32 PM (#50768 - in reply to #50752)
You can see the patching on the left side. It actually looks better in person. The sticker is from StandingO. I miss that guy.
Posted 2008-03-10 9:35 PM (#50769 - in reply to #50752)
Duct Tape.
Light Brown.
Posted 2008-03-10 9:41 PM (#50770 - in reply to #50752)
"Duct Tape.
Light Brown."
Wrap several times around ukulele player. Smile and repeat.
Posted 2008-03-10 9:48 PM (#50771 - in reply to #50752)
You can thank Mr. Naphtha! ;)
