OP Pro pre amp
sohara1111
Posted 2012-11-15 5:09 PM (#461869)
Subject: OP Pro pre amp
November 2012
The tuner function on my OP Pro is not working. I put a new battery in so I know this is not the problem. In the LED screen the letter "r" appears when I strike a string in tuner mode? Does anyone know what this means? Thanks in advance
Posted 2012-11-16 6:31 PM (#461920 - in reply to #461869)
Subject: Re: OP Pro pre amp
I was waiting for someone with more knowledge to answer your question... but that ain't happenin'.
I just messed with my OP-Pro and I cannot re-create your problem.
The only thing that I can think of is that the polarity of you battery is reversed... hence the "r".
I don't know how that could happen and I couldn't bring myself to intentionally do it to my preamp just to find-out.
So... I don't know if that helps.
Maybe you could contact Ovation customer service HERE
Meanwhile... Stick Around, someone will be along to update your account eventually.
sohara1111
Posted 2012-11-16 7:41 PM (#461923 - in reply to #461920)
November 2012
Thanks for your response. The battery is in correctly, however, I did the the battery out and let it sit for a few minutes. That seemed to work at least for E, A, G and then it went back to "r". I emailed Ovation CS, they said if the pre amp worked through an amp, it does, that the tuner is bad and I need to get a new unit . Guess I'll just tune externally. That's again.
