XLR - Balanced v Unbalanced
| TAFKAR |
Joined: April 2008 Posts: 2985 Location: Sydney, Australia | I know that the XLR output from my VIP preamp is "balanced" and that the 1/4" output is "unbalanced", but what does this actually mean (apart from "different")? Can anyone explain the physics of this to me in terms I can understand? I get that I can plug from the XLR directly into the microphone inputs of a PA (which is handy when they are only set up for mikes and don't have 1/4" unbalanced inputs), but what is the actual difference in the signals? | ||
| muzza |
![]() Joined: August 2005 Posts: 3736 Location: Sunshine State, Australia | Not my words, but a google search found the following, which seems like a believable explanation; There's more, but by the time I'd read the above, I understood. Good question, glad you asked it. Now I know too. | ||
| TAFKAR |
Joined: April 2008 Posts: 2985 Location: Sydney, Australia | Thanks Muzz. Almost leads to the question why we use unbalanced signals at all if the balanced is so superior. | ||
| JohnW63 |
Joined: August 2012 Posts: 227 | On short runs the need for balanced is not very high and the cost of the ends and cable is less. Also, not everything HAS an xlr connection to use. | ||
| noah |
Joined: December 2004 Posts: 1673 Location: SoCal | It is not as much the cost of the interconnecting cable, as it is the additional cost of the balanced output and input circuitry. | ||
| muzza |
![]() Joined: August 2005 Posts: 3736 Location: Sunshine State, Australia | Horses for courses. | ||
| FlySig |
Joined: October 2005 Posts: 4089 Location: Utah | I believe that the balanced cable has much lower capacitance, which means the balanced cable does not degrade the high frequencies. On short runs it isn't a big deal, but if you are running long distances it can really add up to a deader sound with the old fashioned guitar cord. Not grounding the braided cable can prevent ground loops. Ground loops can induce 60hz hum from the mains power. | ||
| kitmann |
Joined: April 2010 Posts: 1227 Location: Connersville, Indiana | Thanks Muzza, I was wondering that myself, but was scared to ask. All I knew was that I could use a splitter and run two amps didn't know the physics of it. Now things I did in the studio the engineer wanted me to do makes sense now. | ||
| Mr. Ovation |
Joined: December 2001 Posts: 7251 Location: The Great Pacific Northwest | Just a note... when buying balanced cables, this line above that is sort of glossed over becomes important depending on the use.. "The ground shield may not even be connected at both ends of the cable - in fact it is often left unconnected at the receiving end." If you are using Phantom power on the line, not having the ground lead will be an issue, as it won't work. Phantom power usually needs that ground wire. | ||
| kitmann |
Joined: April 2010 Posts: 1227 Location: Connersville, Indiana | Mr. Ovation when buying balanced cables how do we check them to make sure the ground shield is working or does it depend on the PA system or equipment your plugging into that makes the difference? | ||
| Mr. Ovation |
Joined: December 2001 Posts: 7251 Location: The Great Pacific Northwest | kitmann - 2012-09-24 5:32 PM Mr. Ovation when buying balanced cables how do we check them to make sure the ground shield is working or does it depend on the PA system or equipment your plugging into that makes the difference? I never leave home without my http://www.behringer.com/EN/Products/CT100.aspx Note the led matrix that shows exactly how the cable is wired and if any wires are reversed. It can also sense phantom power and send a test tone. For under $30.00 bucks it's a handy investment that you'll wonder how you lived without.
