getting rid of "pings"
| Damon67 |
Joined: December 2006 Posts: 6996 Location: Jet City | This maybe a topic solely for UKII folks. My UKII has developed a case of the "pings". You know, when you go to tune it, and right before you hit the perfect pitch, you hear the "ping" and it takes you beyond? It'a a brass nut, that's why I'm saying it may just be for the UKII folks out there. It's probably the nut, right? It stays there, even after a string change. I think it's the D or G string | ||
| an4340 |
Joined: May 2003 Posts: 4389 Location: Capital District, NY, USA Minor Outlying Islands | Try a drop of graphite? Try different strings? | ||
| Capo Guy |
Joined: December 2004 Posts: 4394 Location: East Tennessee | Try taking an old which ever string it is and run it back and forth through the slot and see if you feel any roughness. | ||
| 2ifbyC |
| Joined: December 2006 Posts: 6268 Location: Florida Central Gulf Coast | I've read that a bit of graphite in the nut slots may help. | ||
| Paul Templeman |
Joined: February 2002 Posts: 5750 Location: Scotland | The nut slot has worn out, not uncommon with brass, it's a relatively soft metal. Short-term fixes - get some graphite from an HB pencil, grind it into a powder and put it into the slot, you'll need to repeat this every time you change strings. A better bet is graphite-based firearm lubricant paste or buy some BigBends Nut Sauce which is the same kinda stuff for guitars but a lot more expensive. Medium term fix - shim the nut up just a hair and re-cut the slots. The real fix. Ditch the brass and have a bone nut installed | ||
| Damon67 |
Joined: December 2006 Posts: 6996 Location: Jet City | I use Dean Markley Custom Lights on pretty much all the electrics. I doubt it's the string's fault. A drop of graphite? Would they have that at a music store? I'll try the string thing Capo Guy. If there seems to be a rough edge, I'll end up bringing it to a local shop. What will they do, take a file to my UKII? :eek: | ||
| Damon67 |
Joined: December 2006 Posts: 6996 Location: Jet City | Paul, you posted same time as I. I'll try the lube/graphite first I think. I don't want to lose that brass nut. | ||
| Damon67 |
Joined: December 2006 Posts: 6996 Location: Jet City | I wonder... You think the Mothership might have a nut floatin' around still? Or.... MILES???? | ||
| Paul Templeman |
Joined: February 2002 Posts: 5750 Location: Scotland | Originally posted by Damon67: Why not? It was a late '70's fad, no other Ovation solids had a brass nut. Apart from being cheap, available and easy to work, brass has absolutely no advantage over traditional materials like bone or good synthetic bone substitutes like Corian, Micarta or Tusq. There are good reasons why hardly anyone uses brass nuts anymore.I don't want to lose that brass nut. | ||
| moody, p.i. |
Joined: March 2002 Posts: 15680 Location: SoCal | In my line of work, brass nuts (big ones) are a good thing..... | ||
| Paul Templeman |
Joined: February 2002 Posts: 5750 Location: Scotland | Mr Moody... the master of the single entendre. | ||
| colt357 |
Joined: September 2006 Posts: 713 Location: Alberta, Canada | Oh...so this isn't about golf? | ||
| Damon67 |
Joined: December 2006 Posts: 6996 Location: Jet City | Originally posted by colt357: Not if I started the post. I have a hard time when i get to the Windmill. Timing is everything. :D Oh...so this isn't about golf? I have to contemplate the nut issue. I spose it's not invasive, and it can always be swapped back later, right? | ||
| Paul Templeman |
Joined: February 2002 Posts: 5750 Location: Scotland | Right. | ||
| FlicKreno aka Solid Top |
Joined: April 2006 Posts: 2491 Location: Copenhagen Denmark | How about doing it the FENDER -way , use a tiny drop of acid -free oil ( in between Nut -String ) Vic | ||
| Old Man Arthur |
Joined: September 2006 Posts: 10777 Location: Keepin' It Weird in Portland, OR | As to Graphite... You can get some relatively cheap graphite at Home Desperate (or some such hardware store) for lubricating Locks. It'll come in spray, but they should have some liquid sh... uh, stuff ['scuse me]. Or get the spray, and spray it in the cap that came with the can. One purchase oughta last you a lifetime. | ||
| Paul Templeman |
Joined: February 2002 Posts: 5750 Location: Scotland | It needs to be in paste or gel form so it stays put. Sprays and oils just run right out of the nut slots. | ||
| Old Man Arthur |
Joined: September 2006 Posts: 10777 Location: Keepin' It Weird in Portland, OR | Originally posted by Paul Templeman: My bad... It needs to be in paste or gel form so it stays put. Sprays and oils just run right out of the nut slots. [did I just use that cliche? :mad: ] | ||
| 2ifbyC |
| Joined: December 2006 Posts: 6268 Location: Florida Central Gulf Coast | Quite a while ago I was given a nozzle-tipped small tube of graphic that was in some type of 'suspension'. It was used for locks during wintertime up 'yonder'. Maybe that would help you. | ||
Joined: April 2006 Posts: 2491 Location: Copenhagen Denmark | A small amount of " lip -balm " instead of - 3 in 1 oil - works wonders.... Vic | ||
| Damon67 |
Joined: December 2006 Posts: 6996 Location: Jet City | I think I'll try out the gun stuff first, cuz I love my ol' girl just the she is, but I'm still contemplating that nut replacement. Any suggestions on a replacement? | ||
