anyone bord want explain humidity to this guy?
PEZ
Posted 2012-06-06 12:57 PM (#455307)
Subject: anyone bord want explain humidity to this guy?
July 2003
http://www.youtube.com/watch?v=e6n-9PI3Cx8
Posted 2012-06-06 1:11 PM (#455308 - in reply to #455307)
Subject: Re: anyone bord want explain humidity to this guy?
very eloquent
he should play a trailer
martinez
Posted 2012-06-06 3:36 PM (#455311 - in reply to #455307)
September 2011
Wow, I want to avoid that happening to mine!!! I've never in my life thought about "humidity" .....maybe I should start!
Darkbar
Posted 2012-06-06 4:29 PM (#455312 - in reply to #455311)
January 2009
Ha! PEZ has 6 responses in a row. GET 'Em PEZ!!!!
javaman
Posted 2012-06-06 5:24 PM (#455315 - in reply to #455307)
January 2007
Well I doubt that a response will ever get back to this guy, but a word to the wise is to keep your solid wood guitars humidified to around 45% humidity to prevent this from happening. It happened to my Balladeer years ago because I didn't know how to care for a solid wood top. When I bought my Taylor it came with a humidifier. I went out and bought a hygrometer from a cigar store to keep in my cases. I now place a piece of sponge in a small plastic container with holes punched in it (that I picked up at a dollar store), and keep it moist (not dripping wet) in my solid wood guitar cases. I even put one in an electric case when I discovered "fret spout" in the neck, which was caused by the neck getting dry and shrinking slightly.
When I found my Balladeer cracked I took a full sized wet sponge and put it in the guitar body and left it in the case for a day. When I checked on it the crack had completely closed up, so I let it dry for a week or so and used wood glue in the crack and held it together with a clamp. Then let it set for a few days. That was a few years ago and it is still holding. Oh yeah, the bridge came off also. I used Titebond wood glue and some very small screws to hold it on. This is probably not the recommended repair technique, but everything is still holding together and sounding good.
Posted 2012-06-06 7:09 PM (#455318 - in reply to #455307)
Its gotta be the accent...
Q: Waddya tell an idiot wid two black eyes?
A: Nuthin! He didn't listen the first two times...
