3/100ths of an inch makes all the difference in the world!
aaronharmon
Posted 2012-05-23 1:02 PM (#454882)
Subject: 3/100ths of an inch makes all the difference in the world!
October 2009
I just got my 4th US Elite within the last week or so and its very close in serial number to one of the same model that I already had. How close? How's 5 apart? They are XXXX80 and XXXX86 with all other numbers being the same. I thought that was pretty cool. The funny thing is right out of the box, the new one is not nearly as playable as the other one. It has some annoying string buzz and is just a little tougher to fret cleanly. I started looking for the culprit and found it right away. Someone removed a shim from under the saddle. It only lowered the strings 3/100th of and inch, but that reeked havoc on the setup. This just goes to show that lower is not always better/more playable.
On a related note, Does anyone have any spare shims that they wouldn't mind sending me? I used to, but I gave them to a friend in need a year or so ago.
Posted 2012-05-23 2:55 PM (#454888 - in reply to #454882)
Subject: Re: 3/100ths of an inch makes all the difference in the world!
Slices cut off an old credit card work nearly as well.
Posted 2012-05-23 3:04 PM (#454890 - in reply to #454882)
which shims you need depends on which pickup assy is in there. The newer models don't have pins that go though, so the shims are longer.
Darkbar
Posted 2012-05-23 4:22 PM (#454892 - in reply to #454888)
January 2009
boltonb - 2012-05-23 3:55 PM
Exactly! Just make you own shims...it ain't rocket science.
aaronharmon
Posted 2012-05-23 6:10 PM (#454896 - in reply to #454888)
October 2009
Credit card is too thick. I thought of putting a layer or two of tape on the existing shims, but I didn't know if it would affect the tone. Plus it wouldn't be original.
Edited by aaronharmon 2012-05-23 6:12 PM
aaronharmon
Posted 2012-05-23 6:10 PM (#454897 - in reply to #454890)
October 2009
damon67 - 2012-05-23 4:04 PM
Its the newer style OP-Pro Studio
Posted 2012-05-23 6:45 PM (#454900 - in reply to #454882)
customer service could probably do something for you. Ask for John or Kim.
