Ovation Amplifiers - Need Info - I found one!!
iglupickin
Posted 2012-05-21 6:37 PM (#454824)
Subject: Ovation Amplifiers - Need Info - I found one!!
In the late 60's I had an Ovation Guitar amplifier with the seperate head with Fuzz, tuner, reverb etc and a powered speaker cab with (4) 12" speakers and (2) horns with a knob to set the amount of high frequency to the horns. I regretted giving that up for something lighter but I bought it when BIG was the style but later it was to heavy to haul around to gigs. After all these years, I'm jammin with a friend and he says he's got some old amp he's about to toss out since its been sitting in his shed for ages. Low and behold its an Ovation!!! Same K6002 head as the one I owned but a smaller powered speaker cab with (2) 12" speakers and a single horn!! Hard to find info on these old dogs like schematics, specs, etc for testing and repair so I'm searching for sources of info. I would appreciate anything anyone can share.
Gary
-Ovation 1986 Collectors Shallow bowl
-Ovation 1986 Classical
- Guild J31 Jumbo Acoustic
Posted 2012-05-21 6:58 PM (#454826 - in reply to #454824)
Subject: Re: Ovation Amplifiers - Need Info - I found one!!
I don't have any schematics... They are pretty straight forward electronically. As far as parts, you'd need to trouble-shoot to component level which is not that difficult. I don't recall any proprietary parts other than the boards themselves, but it's been awhile since I've been inside one. I plan on fixing a bunch up for sale in the very near future. By fix up, I just mean test and make sure they still work.
Miles
Posted 2012-05-22 8:35 AM (#454832 - in reply to #454826)
mileskb - 2012-05-21 6:58 PM I plan on fixing a bunch up for sale in the very near future. Miles
Based on my observation of the contents of your boathouse, "a bunch" would be an understatement unless you plan on keeping most of them.  I wouldn't be surprised if you had the world's largest inventory of Ovation amps.
Posted 2012-05-22 2:24 PM (#454846 - in reply to #454832)
boltonb - 2012-05-22 6:35 AM
Yeah, I should adopt your tagline..
I had (maybe still have) the most Ovation Electrics in the world so it seemed only fitting to have the most amps
iglupickin
Posted 2012-05-22 5:48 PM (#454856 - in reply to #454824)
Who made the speakers for Ovation back then? I think this cab was dropped since the magnet and cap with logo seperated from the speaker frame.
Thanks for the info. I assume the head is putting out standard line level audio to the power amp? If so, I can test that portion and focus on the amplifier caps, transistors, etc. thanks for the feedback.
Posted 2012-05-23 2:36 PM (#454887 - in reply to #454856)
iglupickin - 2012-05-22 3:48 PM
YOU may be the ONE to help us figure that out. I dedicated a large portion of my weekend before the Seattle/Tacoma Guitar show on this very question and came up empty..
Are there ANY numbers, letters or markings under that cap, likely on the back of the magnet or base of the basket under where the cover was. I have several of these speakers that are in essentially new condition and we believe they are Eminence or CTS however, the only markings I have ever found are form LCC who is a company that makes cones for some of the other speaker manufactures. I have my fingers crossed there are some numbers on the back of the actual magnet....
iglupickin
Posted 2012-05-24 8:12 PM (#454965 - in reply to #454887)
After pealing off the Ovation emblem and unscrewing the nut that holds the cover, underneath is a plain steel plate with only a few markings. they look like stamps. Two circles with the letters "U" and "S" next to each other and a 4 digit number 8901 as best as I can tell. I'd send a picture but there isn't much to see beyond what I described. I hope this helps.
Gary
Posted 2012-05-24 11:22 PM (#454970 - in reply to #454824)
That is helpful. Not sure how helpful yet, but I'm guessing the U and the S are significant. The 8901 isn't breaking out to any manufacturer yet, but I'll keep working on it. By the way, if you need a replacement speaker... which speaker do you need? Should say Audient 80 or Audient 50 etc..
iglupickin
Posted 2012-05-25 6:46 AM (#454982 - in reply to #454824)
It's actually an Audient 100 Model 9702. I'll let you know. It's great to know there are some parts out there but I got to get the amp working first. Also the horn driver is missing. Got one? Apparently thats where the mice got in the cabinet to build a nest amidst the matting inside!!
TJR
Posted 2012-05-25 11:23 AM (#454992 - in reply to #454824)
July 2002
might be University Sound ?
I will need to verify, but I have a set (or two) of Cabinet mounted mid-range/tweeter horns that the drivers are Gold (University Sound), or pale blue marked Kaman. Again .. I need to verify this when I get home.
I also have a 4 pieces set of "NIB" 12 woofers for one of the Kaman speaker/amp cabinets. The box had some marking, I can try to dig out. Most of the 15" woofers I've seen were JBL D130's or slightly modified versions of that speaker.
Edited by TJR 2012-05-25 11:26 AM
Posted 2012-05-25 2:08 PM (#454998 - in reply to #454824)
I have horns and speakers. Not sure I have the Audient 9702, but I might have a different model same size. Let me know the sizes and we check the catalogs to see the differences.
iglupickin
Posted 2012-05-25 7:00 PM (#455009 - in reply to #454824)
The hefty frames, more expensive screw terminals that are uniquely mounted on opposite sides of one pillar of the speaker frame looks similar in design to an Altec Lansing 421 I looked at on E-Bay. Also consider how many manufacturers used an aluminum castings for the magnet cover, a rather pricey piece of metal that is more cosmetic than functional seems to point to a brand above the usual stamped steel frames and open magnets of other common speaker brands. Some thoughts
Gary
Posted 2012-05-25 8:18 PM (#455012 - in reply to #454824)
I believe University Sound became Altec, so I think we're on the right track.
iglupickin
Posted 2012-05-26 6:39 AM (#455020 - in reply to #454824)
I read that also. Good info for sure!
Posted 2012-05-27 2:14 PM (#455038 - in reply to #454824)
eventually altec purchased University sound. they also made drivers etc for them. University had mics that were made by shure and branded university as well as altec.
at that time university built a ton of outside enclosures altec built indoor theater stuff and it was not uncommon for these companies to offer products with their own brand built by other companies.
for example I have an atlas studio mic stand branded with an RCA meatball and s/n I am sure an RCA geek would pay big $$$ for it but to me it is a stand in my studio.
the drivers were probably made by university the speakers I believe are cts
iglupickin
Posted 2012-05-28 3:29 PM (#455064 - in reply to #454824)
The horn driver was missing and I just cleaned out the bottom of the cabinet from years of mice habitation!!!! I'll starting working on the amp to see if its workable. The good thing it was dry. Once speaker is all there and should test out ok. The other will have to be replaced. I may be looking for a Audient 100 12" speaker and a horn driver at some point but once the amp and head are working, I can deal with the rest. It would be a nice amp for my 86 Ovation Collectors shallow bowl especially with the horn to drive the highs!!
Posted 2012-05-28 9:50 PM (#455075 - in reply to #454824)
Email me at mileskb at aol.com when ur ready. I have plenty of 12" Audients (Ovation) and Ovation horns as well.
TJR
Posted 2012-05-28 11:58 PM (#455083 - in reply to #454992)
July 2002
Here's the pics of the Misc items I have.. (or had, the larger dual JBL 15" woofers were sold a while back. )
https://picasaweb.google.com/104209077305164586938/OvationAmpsMisc?a...
The Large horns are "Cobraflex" horns by University Sound.
Maybe some of this info will help figure something out.
TJR
