plugged in
| Fridave |
Joined: February 2008 Posts: 247 Location: Delaware | Does the type of string (bronze, phos/bronze, nickle, etc.) have an effect on the amplified sound of an O, or any git. The saddle pickup just transfers the vibrations of the strings doesn't it ? Curious how much the metallic makeup has to do with plugged in sound/tone ? Any thoughts / info appreciated. | ||
| G8r |
Joined: November 2006 Posts: 3969 | Originally posted by fridave: Since THE authority on this subject (Temp) is probably boozin' it up with Cliff right now, I'll take a stab at it. You're right about the saddle just transferring vibrations to the peizos, which then discharge the electrical impulses. My guess is that the string composition wouldn't have any effect on this, especially since the nylon string guitars use the same pickups as the steel stringers. It's not like an electric guitar where you have induction generating the electrical output from the pups. On the other hand, electric git strings are much thinner than what you'd put on an acoustic, and probably wouldn't have the volume or sustain. The saddle pickup just transfers the vibrations of the strings doesn't it ? Curious how much the metallic makeup has to do with plugged in sound/tone ? Any thoughts / info appreciated. I'm sure I'll be roundly criticized (or should I say criticised?) if I'm wrong. | ||
| PEZ |
Joined: July 2003 Posts: 3111 Location: Nashville TN. | Saw a guy using electric strings on a Balladeer early 80s V&T stacked. It sounded tinny thin horrable. | ||
| Fridave |
Joined: February 2008 Posts: 247 Location: Delaware | I'm sure I'll be roundly criticized (or should I say criticised?) if I'm wrong. g8r, at least you took a shot at it, and I'm kinda thinkin you're right. Maybe we'll both get criticised ! Hey please tell me Cliff doesn't drink (and play). | ||
| 2ifbyC |
| Joined: December 2006 Posts: 6268 Location: Florida Central Gulf Coast | Originally posted by g8r: No criticism from here. But there is a difference twix strings and the harmonics each type produce. Plus the body style, depth and where you pick/strum the strings affect the tone and harmonics. Using the electronics will allow adjustment to the resulting waveforms. Then toss in the amp you're using and it's settings. I'm sure I'll be roundly criticized (or should I say criticised?) if I'm wrong. So the possibilities are nearly endless. Ergo the search for the individual 'holy grail'. This alone drives the guitar/strings/amp/etc. industry. This topic can go on forever with no one answer. That's just my . I'm sure others will be along to contribute to this interesting subject... | ||
| Fridave |
Joined: February 2008 Posts: 247 Location: Delaware | The reason I ask is I had D'ad 12-53 bronze on my 1717, got it dialed in and sounding great on a bose pas, changed strings to check out Adamas 1818e phos/bronze, same settings on O and pas but I it seems to sound different. Maybe it's me. Maybe I need a (another) drink ! | ||
| G8r |
Joined: November 2006 Posts: 3969 | Interesting experiment. I've never noticed that, but then again I mostly play unplugged (or mic'ed for recording). Don't drink & pick! The ears you fool are only your own (see the other recent thread on that subject). | ||
| an4340 |
Joined: May 2003 Posts: 4389 Location: Capital District, NY, USA Minor Outlying Islands | yes. that's one of the reasons they make strings from different materials | ||
| Jeff W. |
Joined: November 2003 Posts: 11039 Location: Earth·SolarSystem·LocalInterstellarCloud·Local Bub | Absolutely. Strings do make a difference... That's why a nylon string guitar sounds different than a steel string.... within same string types it's a matter of lesser degrees and gauge etc... | ||
| cliff |
Joined: March 2002 Posts: 14842 Location: NJ | If you're changing-out strings that've been "broken-in" with BRAND new (esp. PhosBrnz.) they're gonna' sound VERY brite/brassy til they get "settled-in". | ||
| Paul Templeman |
Joined: February 2002 Posts: 5750 Location: Scotland | Any tonal difference between bronze and Phos bronze once they've settled-in is pretty subtle, amplified or not. The difference between bronze alloys and nickel is huge, amplified or not. | ||
| cliff |
Joined: March 2002 Posts: 14842 Location: NJ | It's about time you got your drunk arse outta' bed!!! Get off my computer and go feed th'fookin' cats . . . | ||
| cliff |
Joined: March 2002 Posts: 14842 Location: NJ | . . . and iron my golf shirt. | ||
| Jeff W. |
Joined: November 2003 Posts: 11039 Location: Earth·SolarSystem·LocalInterstellarCloud·Local Bub | I'm hearing "Odd Couple" theme music... | ||
| Weaser P |
Joined: October 2005 Posts: 5333 Location: Bluffton, SC | Funny - I heard "Grumpy Old Men". | ||
| Waskel |
Joined: February 2005 Posts: 11840 Location: closely held secret | "Odd Couple of Grumpy Old Men". | ||
| Jeff W. |
Joined: November 2003 Posts: 11039 Location: Earth·SolarSystem·LocalInterstellarCloud·Local Bub | either way... it's all a bit disturbing. | ||
| stephent28 |
Joined: April 2004 Posts: 13303 Location: Latitude 39.56819, Longitude -105.080066 | What's disturbing is that we are all flying down to Florida to hang out with these two degenerates. | ||
| G8r |
Joined: November 2006 Posts: 3969 | If they break out Taylors and start singing Viva Viagra I'm outta there! | ||
| cliff |
Joined: March 2002 Posts: 14842 Location: NJ | They only thing that I'LL play on a Taylor involes a Porter-Cable cordless and a 3/4" auger bit . . . | ||
| G8r |
| 2ifbyC |
| Joined: December 2006 Posts: 6268 Location: Florida Central Gulf Coast | Originally posted by cliff: A Taylor with Adamas holes... BRILLIANT! They only thing that I'LL play on a Taylor involes a Porter-Cable cordless and a 3/4" auger bit . . . | ||
| cliff |
Joined: March 2002 Posts: 14842 Location: NJ | 60 or 70 of 'em . . . but Adamas holes nonetheless . . . | ||
plugged in
