What capo for 1581?
Posted 2009-01-04 4:15 PM (#435113)
Subject: What capo for 1581?
Dear Abby, is it the shape of the fretboard on the 1581 that causes intonation problems with my Kyser? If I get it in tune and slap the Kyser on the 2nd fret, then play a G chord, the top string (A note) is sharp. Tell me what to do.
G8r
Posted 2009-01-04 4:34 PM (#435114 - in reply to #435113)
Subject: Re: What capo for 1581?
Get a Schubb - seriously.
kotadawg
Posted 2009-01-04 5:08 PM (#435115 - in reply to #435113)
November 2007
I had the same problem on it with my Kyser, Jas. I don't think the Kyser and the 1581 neck are a good match.
Posted 2009-01-04 5:32 PM (#435116 - in reply to #435113)
+1 on the Shubb. Or a G7.
Posted 2009-01-04 6:05 PM (#435117 - in reply to #435113)
Very helpful. Thanks.
Posted 2009-01-04 7:30 PM (#435118 - in reply to #435113)
No probs with a Victor. The arched bar may have an impact.
Posted 2009-01-05 6:17 AM (#435119 - in reply to #435113)
This is one of several reasons why I won't use a non-adjustable capo such as the Kyser. Kysers will work perfectly on many guitars, but there will be some set-ups where the clamping pressure is too strong (or too weak) for the string guage/action/neck releif/fret bead height and that will cause problems. There are a ton of capos such as the Shubb, G7, Victor, Paige and others where the clamping pressure is finely adjustable. Any of those should solve your problem
Posted 2009-01-05 6:28 AM (#435120 - in reply to #435113)
Try a Planet Waves NS Capo. They are finely adjustable, and very small and light.
[And Cheap! :D ]
Alittle bit bigger than this photo.
Posted 2009-01-05 6:32 AM (#435121 - in reply to #435113)
use a pencil and a rubberband...
Posted 2009-01-05 6:52 AM (#435122 - in reply to #435113)
The curve is the issue. I may need a rubber pencil. I'll head over to Eddie's Trick Shop and get one. I was needing some fake bullet holes and a whoopie cushion anyway. I am just about out.
Gallerinski
Posted 2009-01-05 7:02 AM (#435123 - in reply to #435113)
Spring loaded capos will give intonation problems. Period. Although I use one just 'cuz it's so easy ...
